I have a QApplication on TX2 that renders on HDMI.
X11 is completely disabled and not present in system.
I use KMS/DRM as plaform for rendering, hence my startup configuration is:
QT_QPA_EGLFS_LAYER_INDEX = 2
QT_QPA_EGLFS_KMS_PLANE_INDEX = 1
QT_QPA_EGLFS_KMS_CONNECTOR_INDEX = 0
QT_QPA_PLATFORM = eglfs
QT_QPA_EGLFS_INTEGRATION = eglfs_kms_egldevice
QT_QPA_EGLFS_KMS_ATOMIC = 1
QT_QPA_EGLFS_ALWAYS_SET_MODE = 1
QCoreApplication::setAttribute(Qt::AA_ShareOpenGLContexts);
Whereas these setting work on QT 5.12 I am not able to make it work using QT 5.6.3, which is QT version I have to use in final product.
I see that KMS/DRM is supported Qt for Embedded Linux | Qt 5.6
I also see in log correct startup, see following log excerpt:
loaded library "/usr/lib/qt5/plugins/egldeviceintegrations/libqeglfs-kms-egldevice-integration.so"
qt.qpa.eglfs.kms: New DRM/KMS on EGLDevice integration created
qt.qpa.egldeviceintegration: Using EGL device integration "eglfs_kms_egldevice"
qt.qpa.eglfs.kms: Found 1 EGL devices
qt.qpa.eglfs.kms: Opening drm-nvdc
qt.qpa.eglfs.kms: Using connector with type 11
qt.qpa.eglfs.kms: Using crtc 1000 with mode 1920 x 1200 @ 59
qt.qpa.eglfs.kms: DRM/KMS initialized
qt.qpa.eglfs.kms: Creating display
qt.qpa.eglfs.kms: Creating stream
qt.qpa.eglfs.kms: Created stream 0x5588cecd91 on display 0x5588b15f00
qt.qpa.eglfs.kms: Output has 6 layers
qt.qpa.eglfs.kms: [0] layer 0x5588b1e0e1 - crtc 1000
qt.qpa.eglfs.kms: [1] layer 0x5588b1fde1 - crtc 1001
qt.qpa.eglfs.kms: [2] layer 0x5588b1fa11 - plane 4001
qt.qpa.eglfs.kms: [3] layer 0x5588b1fa41 - plane 4002
qt.qpa.eglfs.kms: [4] layer 0x5588b1faf1 - plane 4004
qt.qpa.eglfs.kms: [5] layer 0x5588b1fb21 - plane 4005
qt.qpa.eglfs.kms: Using layer 0x5588b1fa11
qt.qpa.eglfs.kms: Stream producer format is QSurfaceFormat(version 2.0, options QFlags(), depthBufferSize 0, redBufferSize 8, greenBufferSize 8, blueBufferSize 8, alphaBufferSize 0, stencilBufferSize 0, samples 0, swapBehavior 0, swapInterval 1, profile 0)
qt.qpa.eglfs.kms: Creating stream producer surface of size 1920x1200
qt.qpa.eglfs.kms: Created stream producer surface 0x5588b2d611
Created context for format QSurfaceFormat(version 2.0, options QFlags(), depthBufferSize 0, redBufferSize 8, greenBufferSize 8, blueBufferSize 8, alphaBufferSize 0, stencilBufferSize 0, samples 0, swapBehavior 2, swapInterval 1, profile 0) with config:
EGL_BUFFER_SIZE: 24
EGL_ALPHA_SIZE: 0
EGL_BLUE_SIZE: 8
EGL_GREEN_SIZE: 8
EGL_RED_SIZE: 8
EGL_DEPTH_SIZE: 0
EGL_STENCIL_SIZE: 0
EGL_CONFIG_CAVEAT: 12344
EGL_CONFIG_ID: 20
EGL_LEVEL: 0
EGL_MAX_PBUFFER_HEIGHT: 32768
EGL_MAX_PBUFFER_PIXELS: 1073741824
EGL_MAX_PBUFFER_WIDTH: 32768
EGL_NATIVE_RENDERABLE: 0
EGL_NATIVE_VISUAL_ID: 0
EGL_NATIVE_VISUAL_TYPE: 12344
EGL_SAMPLES: 0
EGL_SAMPLE_BUFFERS: 0
EGL_SURFACE_TYPE: 2049
EGL_TRANSPARENT_TYPE: 12344
EGL_TRANSPARENT_BLUE_VALUE: 0
EGL_TRANSPARENT_GREEN_VALUE: 0
EGL_TRANSPARENT_RED_VALUE: 0
EGL_BIND_TO_TEXTURE_RGB: 0
EGL_BIND_TO_TEXTURE_RGBA: 0
EGL_MIN_SWAP_INTERVAL: 0
EGL_MAX_SWAP_INTERVAL: 0
I tried various combinations, but no rendering works
No logs in kernel.
Can you help me understand if QT 5.6.3 DRM is maybe not supported on TX2 or if there is some different settings I have to use ?
Martin
