Environment
Headset: Meta Quest 2
OS: Pop!_OS 22.04 (Xorg session)
GPU: NVIDIA GeForce RTX 5070 Ti
Driver: 580.82.07 (user-space + kernel)
Vulkan:
vulkaninfolists GPU 0 = NVIDIA RTX 5070 Ti -
Isaac Sim: 4.5 (Linux)
OpenXR extensions in Isaac:
omni.kit.xr.system.openxrenabled -
Runtimes tried: SteamVR OpenXR and WiVRn (Flatpak)
WiVRn dashboard log:
Driver "NvidiaProprietary" "580.82.7.0"
What I’m trying to do
Use Meta Quest 2 controllers inside Isaac Sim.
Ideally I’d like to know if controllers can work without SteamVR (i.e., with WiVRn only). If SteamVR is required, I’d like guidance to fix my SteamVR startup issue on Linux.
Current behavior
With SteamVR: when I try to bring it up, I repeatedly get “Restart SteamVR” and it never stabilizes. Because of this, I tested WiVRn instead.
With WiVRn (OpenXR runtime): Isaac Sim connects to the HMD; in-HMD I see both controllers and Isaac Sim also visualizes them. But they don’t move—no pose updates and buttons don’t affect anything. They just stay fixed in place (screenshot attached).
Errors / logs I’ve seen
Earlier, when WiVRn was selecting a non-NVIDIA ICD, I hit:
Failed allocate Vulkan Instance/Device for OpenXR -
xrGetVulkanGraphicsDeviceKHR: result: VK_ERROR_EXTENSION_NOT_PRESENT(list includedVK_EXT_depth_range_unrestricted) -
XR_ERROR_FORM_FACTOR_UNSUPPORTED
After forcing NVIDIA ICD for WiVRn, the HMD session comes up, but controller pose/buttons are still not updating in Isaac Sim.
What I’ve already tried
Ensured NVIDIA Vulkan ICD is used when launching Isaac Sim (
__GLX_VENDOR_LIBRARY_NAME=nvidia,VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json), and cleaned env (unset LD_LIBRARY_PATH, deactivated conda). -
Toggled Window > XR > Enable VR and Enable Input in Isaac; OpenXR extension is on.
Verified
vulkaninfopicks NVIDIA RTX 5070 Ti. -
For SteamVR: set SteamVR as OpenXR runtime (
active_runtime.json), removedsteamvr.vrsettings, killed all Steam/VR processes, installed 32-bit Vulkan/GL libs, and tried launchingvrstartupwith NVIDIA ICD forced. Still loops on Restart SteamVR.
Questions
Is Meta Quest 2 controller input supported in Isaac Sim over WiVRn (Monado) without SteamVR?
- If yes, what exact steps and input profile/bindings are required so that pose + buttons update in Isaac? Any sample action map or known-good config?
If SteamVR is required for Quest controllers, are there known steps on Linux (Pop!_OS 22.04, NVIDIA 580) to fix the “Restart SteamVR” loop so Isaac Sim + SteamVR + WiVRn works reliably?
Any Isaac Sim XR Input debugging tips (e.g., how to verify
XrActionpose/button states inside Isaac beyond the XR Input Debugger) that could help pinpoint why the controllers appear but don’t produce pose updates?
Repro steps (WiVRn path)
Launch WiVRn (Flatpak, NVIDIA ICD).
Connect Quest 2 → HMD view is OK, controllers appear.
Start Isaac Sim → Window > XR > Enable VR (+ Enable Input).
Observe: controllers are visible in scene but no pose/button updates.
Repro steps (SteamVR path, desired)
Set SteamVR as OpenXR runtime.
Launch
vrstartup(forcing NVIDIA ICD). -
SteamVR shows “Restart SteamVR” repeatedly and never stabilizes.
Screenshot: controllers visible in Isaac/Quest but not moving.
Can provide
kit_*_log,active_runtime.json,vulkaninfoexcerpts, and SteamVR logs (vrserver.txt,vrcompositor.txt) on request.
Any guidance or a known-working recipe for Quest 2 controllers on Linux would be greatly appreciated. Thanks!
