I have been reviewing several discussions about multi-flash support on Jetson Xavier devices, and I would like to ask for some clarification.
I saw a topic where users mentioned flashing multiple Xavier boards in parallel, and I am trying to understand the real performance improvement
Currently, I am flashing 3 Xavier devices at the same time, but the total flashing time is essentially tripled. I haven’t been able to
So I would
Does multi-flash actually reduce the flashing time per device in pra
If yes, what flashing time are other users achie
Are there recommended configurations (USB3 hubs, host PC specs, JetPack/L4T versions, etc.) to optimize parallel flash
Are there any known limitations when flashing multiple Xavier bo
I want to ensure that I’m using the correct method and that multi-flash should indeed bring performance be
Thank you very much for your support!
Please provide your multi flash commands for us to review.
My multi-flash commands are as follows:
Create massflash image (without flashing immediately, using USB0 network):
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --network usb0 --massflash 5 jetson-xavier-nx-devkit-emmc mmcblk0p1
Flash devices with high I/O priority, keeping the current state:
sudo ionice -c 1 -n 0 ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --flash-only --massflash 5 --keep
Flash again or reset devices if needed:
sudo ionice -c 1 -n 0 ./tools/kernel_flash/l4t_initrd_flash.sh --network usb0 --flash-only --massflash 5 --reseu
Please share the flashing and serial console logs for us to review.
Also, explain how you connected three devices to the host PC.
I connected all three devices on a single USB bus.
Attached is the flashing and serial console log for one of the devices. The other three devices are similar, but they flash very slowly compared to this one.
Please let me know if you need additional details.
Thanks,
Tuan
flash_1-9_0_20251203-155219.log (39.8 KB)
Thanks ~1217
tuan100220:
serial console log
Please record the serial console log as below topic show:
