We found flash.xml bootloader-dtb partition file tegra194-p2888-0001-p2822-0000.dtb.
Its’ same with linux kernel dtb, Did cboot also use dtb or just use it for get kernel
parameter command ?
hello boyi_liao,
you might check Partition Configuration for reference.
thanks
According i traced the source in “tegrabl_get_partition_name” function.
cboot did’t seem to be used “bootloader-dtb” partition,
static char partition_names[TEGRABL_BINARY_MAX]
[TEGRABL_GPT_MAX_PARTITION_NAME + 1] = {
[TEGRABL_BINARY_KERNEL] = {“kernel”},
[TEGRABL_BINARY_KERNEL_DTB] = {“kernel-dtb”},
[TEGRABL_BINARY_KERNEL_DTBO] = {“kernel-dtbo”},
[TEGRABL_BINARY_KERNEL_REC] = {“kernel_rec”},
[TEGRABL_BINARY_KERNEL_REC_DTB] = {“kernel_rec-dtb”},
[TEGRABL_BINARY_RECOVERY_KERNEL] = {“SOS”},
[TEGRABL_BINARY_NCT] = {“NCT”}
I suspect that is because in Xavier/R32.1 U-Boot is not used. Boot of the Linux kernel is from CBoot.
