• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1
• Issue Type( questions, new requirements, bugs) questions
Hi, I’m testing two pipelines based on nvds-anlaytics-test sources.
This is for RTSP Sink. And the source for that is as follows.
nvvidconv1 = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter1");
x264enc = gst_element_factory_make ("x264enc", "h264 encoder");
filter = gst_element_factory_make ("capsfilter", "filter");
caps4 = gst_caps_from_string ("video/x-raw, format=I420");
g_object_set (G_OBJECT (filter), "caps", caps4, NULL);
gst_caps_unref (caps4);
if (!nvvidconv1 || !x264enc || !filter) {
g_printerr ("One element could not be created. %p,%p,%p, Exiting.\n",nvvidconv1, x264enc,
filter);
return -1;
guint udp_port = 5400;
rtppay = gst_element_factory_make ("rtph264pay", "rtp-payer");
sink = gst_element_factory_make ("udpsink", "udp-sink");
gst_bin_add_many(GST_BIN(pipeline), queue1, pgie, queue2, nvtracker,
queue4, tiler,
queue5, nvvidconv,
queue6, nvosd,
queue7, nvvidconv1,
filter, x264enc, rtppay,
sink,
NULL);
x264enc = gst_element_factory_make ("nvv4l2h264enc", "h264 encoder");
caps4 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=I420");
filter);
return -1;
queue4, tiler,
queue5, nvvidconv,
queue6, nvosd,
queue7, nvvidconv1,
sink,
NULL);
The difference between the first and the second is only x264enc and caps4.
*First*
*Second*
Both the first and the second run itself is successful.
But the second code doesn’t seem to be able to export the rtsp video (I can’t get the video from VLC on another PC)
Since the first code does not use NVENC, the CPU usage is high, making it difficult to actually use it. (I can load the video from VLC on another PC.)
In conclusion,
Can I get help with what part of the second code is the problem?
Thank you always.
