Question about the order of pgie, sgie, tracker
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version
hello
If I look at deepstream-app-test2, through the pipeline example of pgie->tracker->sgie, classify has been implemented well.
What I want is a pipeline like pgie->sgie->tracker. Is there any problem with changing the order?
If possible, I want to use the tracker’s interval more, but when inferDone=No, can I get all the meta information about pgie-sgie?
We don’t recommend to change the order. Can you share more details of your project? So we can recommend more efficient pipeline.
hello. We are working on a project related to face-recognition.
  1. pgie
    • detect face and landmark
    • Face-align using opencv through cuda-unified-bufmap
  2. sgie
    • face recognition
  3. tracker
    • [important] Currently only bbox is tracking
because of the information about the entire frame, does the tracker have to come before sgie?
As I said before, the pipeline I want is pgie->sgie->tracker
A few limitations that I think
  1. It is good to receive an aligned image for sgie, but align will fall between Pgie and sgie. (precisely pgie_pad_probe_src)
  2. If the tracker is included, since tracking is not possible track the landmark info, when it is pgie-tracker-sgie, I think the performance will decrease in sgie rather.
Thank you
Does you meet any issue or any performance drop with PGIE->tracker->SGIE? Can you show any issue or perf data to convince we should change the order?
I got landmark information from pgie, but I asked because landmark information is an element that cannot be tracked.
nvtracker only track object based on BBox. Not landmark information.
