Question about UART0 on the M.2 E Slot of Orin Nano Devkit
Hi, Nvidia teams/
I have a couple of questions after reviewing the pin mapping documentation and reference schematics for the Jetson Orin Nano Developer Kit.
Jetson/L4T/peripheral/ - eLinux.org
The pin mapping documentation states:
“UART0 => UART2(PX04, PX05, PX06, PX07): uartb@3110000 (NA) - Unused => To M.2 Key E”
According to the reference schematics, UART0 is connected to the M.2 Key E slot.
My questions are:
  1. Does “Unused” mean that UART0 is disabled by default in the Device Tree?
  2. What is the intended purpose of connecting UART0 to the M.2 Key E slot in the reference design?
Thank you.
“Unused” means this UART is not used by the default software configuration; it does not mean the hardware connection is unavailable. The actual Device Tree status depends on your
JetPack/L4T release. NVIDIA previously confirmed that the M.2 Key E UART is not used by default. Related reply (https://forums.developer.nvidia.com/t/orin-nano-r36-4-uart0-
issue/333255/5)
The UART signals are routed to the M.2 Key E slot to support modules that require UART communication, such as Bluetooth modules using a UART HCI interface. Whether those signals
are used depends on the installed module; the connection does not imply that the supplied Wi-Fi/Bluetooth card uses UART. Related Bluetooth discussion (https://
UART0 flow control - #3 by KevinFFF)
understood. thank you!
