Questions about creating a new tracker in deepstream pipeline
Jetson Orin
• DeepStream Version
6.3
5.1.2
• TensorRT Version
Questions about development
I need to use a custom tracker in an existing Deepstream pipeline. I’ve been reading the docs, and it looks like the easiest/preferred path is to write it as a low-level tracker library, meeting the NvDsTracker API. This tracker will not be using any video, only using the detections from the gpie. I admit that I’m still a bit fuzzy about “caps” and other things that the docs say will be queried. Since the tracker won’t be doing anything with the video, do I need to worry about the video-related information? What other things can I safely essentially “ignore”? I did notice that the video frames will still be passed in, and I think I’ll need to associate the frame number (if present) as part of the tracker return data.
I’ve started looking at the sample code, but my fuzziness of the pipeline API stuff is making it difficult to know where to start, and frankly how much I can not worry about since I’m not doing anything with the video.
My main question is: what “shortcuts” can I take to add a low-level tracker that doesn’t process video?
Please refer IOU tracker here. IOU tracker needn’t visual features: Gst-nvtracker — DeepStream documentation. Please refer the IOU config here: /opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/config_tracker_IOU.yml
The IOU tracker looks like it would be a useful template for how to implement a minimal subset of the API. I don’t see the source code for it in deepstream-6.3. Is that source code (or similarly minimal tracker) available?
No, we haven’t open source low level nvtracker library yet.
Do you know of any sample code that implements a trivial (perhaps even meaningless) but correct implementation of a tracker which doesn’t require video, strictly for the purpose of an API example? I found a post in the forums (link is at bottom of this response), but it still sets pQuery->numTransforms = 1 and sets pQuery->colorFormats[0], implying that it is intending to use the video.
I’m hoping the correct sample code would answer some questions (there will certainly be more) that I have:
(1) if I set numTransforms=0 do I need to even set a value in pQuery->colorFormats?
(2) Does setting numTransforms=0 imply that the pipeline won’t spend cycles transforming the image nor confirming that the image is an acceptable format?
(2b) rewording (2) - if numTransforms is not 0, then does the pipeline spend cycles transforming the image and/or confirming that the image is an acceptable format? In other words, does setting numTransforms=0 save time and/or memory?
You should set numTransforms=0 if your customer tracker needn’t video. Please upgrade to latest DeepStream 7.1 release. You can check the nvtracker plugin code here: /opt/nvidia/deepstream/deepstream-7.1/sources/gst-plugins/gst-nvtracker/
