Hi all!
I would like to use the low-level tracker .so’s provided in Deepstream (eg: libnvds_mot_klt.so) in my non-Gstreamer app which is built using only TensorRT. Could you please guide me on how I can use this for object tracking and unique ID assignment? I will be performing detections with YoloV3 which is already implemented.
Any help would be greatly appreciated!
Our tracker is GStreamer-based implementation so you will need to prepare GStreamer-type input/output.
A sample for launching a gst component can be found here:
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps
For your use case, you can check this topic first:
https://devtalk.nvidia.com/default/topic/1066252/klt-nvmot-usage/
The user want to leverage NvTracker but get stuck in the memory type.
Although we are still checking the possible cause, it should be able to give you some information.
