You explained GPIO3_PBB.0 but I can not make the translation of GPIO_PS.3 to a gpio.
GPIO_PS.3 is gpio 259.
your documentation fails to point out the the GPIO_PS.3 that a second offset of “3” is needed. Offset is defined by MAIN or AON and the second offset is defined by the .3
Please check
https://devtalk.nvidia.com/default/topic/1071855/jetson-tx2/r32-3-1-gpio-question-when-to-use-tegra_main_gpio-or-tegra_aon_gpio/post/5430923/#5430923
Please let us know if you would like to set other pins as gpio pins. We can suggest next.
