hi:
i bring up the sensor ar0820,and then execute this command
“v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100”, Polling execution 100 times,will get stuck。
upload the log。
ar0820-trace.log (703.3 KB)
the kernel log
Ca you please enable the V4L2 debug trace and share the information?
You can enable trace to debug the capture process by running the following commands:
sudo su
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
exit
The trace will give information about VI/CSI.
In order to read the output messages, run:
sudo cat /sys/kernel/debug/tracing/trace
Best,
JDiego Delgado
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.c om/
Website: www.ridgerun.com
hi:
ar0820-trace.log (260.0 KB)
upload log
hi:
My tests found that the following changes caused the card to die,
the error log
sometime there would have been problems without those modifications
See the attachment for log
ar0820-trace-1.log (11.3 MB)
Does your sensor connect with gmsl or ser/deser chip.
Looks like the output frame have include virtual channel ID =1 cause the problem.
kworker/7:3-532 [007] .... 321.042584: rtcpu_vinotify_error: tstamp:10905078368 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:348962381408 data:0x0000000000000589
hi:
we use ser/deser chip, max9295 and max9296.
Looks like the output frame have include virtual channel ID =1 cause the problem.---->How can this problem be fixed。
thanks。
