R38.4.0 can 出现数据报错
hi:
客户遇到 卡死重启之后,can总线上传输数据报错,
dmesg.txt (267.0 KB)
kern.log (21.6 MB)
Hi mingming,
Do you mean the rcu stall issue that you reported in R38.4.0 Encountered a system crash issue - Jetson Systems / Jetson Thor - NVIDIA Developer Forums?
Could a manual reboot help for this issue?
[    3.873051] kernel: CAN device 0 created successfully
[    3.873095] kernel: CAN device 1 created successfully
[    3.873133] kernel: CAN device 2 created successfully
[    3.873165] kernel: CAN device 3 created successfully
[    3.873206] kernel: CAN device 4 created successfully
[    3.873242] kernel: CAN device 5 created successfully
Do you have 6 CAN interfaces in your case?
4 from internal mttcan as following, how about another 2?
[   21.542452] kernel: mttcan 81102f0000.mttcan can3: renamed from canbus0
[   22.329395] kernel: mttcan 8110330000.mttcan can4: renamed from canbus2
[   22.380602] kernel: mttcan 8110300000.mttcan can1: renamed from canbus1
[   22.669127] kernel: mttcan 8110340000.mttcan can5: renamed from canbus3
hi:
Could a manual reboot help for this issue? 重新上下电可以
Do you have 6 CAN interfaces in your case?—-》这块log 忽略,是我们自己加的注册节点记录状态的节点
soc是四个can设备
How about the failed rate in your case?
Pleas also check if reloading the mttcan driver can help for your case.
hi:
概率不大,当时有down 再up起来,也不行,重新加载驱动当时没做这个动作
