hi:
之前在一个帖子讨论zed相机,原厂提供了nito文件,现在不出流,帮忙看看是哪里的问题
agi@tegra-ubuntu:~$ nvargus_nvraw --lps
nvargus_nvraw version 1.17.0
=== nvargus_nvraw[51894]: Connection established (FFFFA78088C0)
Running Power Service HW ISP
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
(NvCamV4l2) Error 0x000a000e: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function verifyDeviceCaps(), line 209)
(NvCamV4l2) Error 0x000a000e: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 69)
(NvCamV4l2) Error 0x0003000f: (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function queryCapabilities(), line 1682)
(NvCamV4l2) Error 0x0003000f: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 68)
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
NvCameraIspGetNitoFilename: nito file /var/nvidia/nvcam/settings/zedx_ar0234.nito found. Badge "zedx_ar0234" SensorModel "" Modulename "zedx_ar0234"
NvCameraIspInitialize: Using NITO /var/nvidia/nvcam/settings/zedx_ar0234.nito
LSC: LSC surface is not based on full res!
NvCameraIspLoadAllNito: NvCameraIspLoadAllConfigFiles and LoadNvCameraKnobFromFile success
BuildSensorModeInfoList: Sensor mode list from Static properties. Count 3
index 0 Res 1920 x 1200 type 4 BPS 10 FPS 60.00
index 1 Res 960 x 600 type 4 BPS 10 FPS 120.00
index 2 Res 1920 x 1080 type 4 BPS 10 FPS 60.00
BuildSensorModeInfoList: NITO Knobset list. Count 4
index 0 Res 1920 x 1080 type 4 BPS 8 FPS 30.00
index 1 Res 1920 x 1200 type 4 BPS 10 FPS 60.00
index 2 Res 960 x 600 type 4 BPS 10 FPS 120.00
index 3 Res 1920 x 1080 type 4 BPS 10 FPS 60.00
BuildSensorModeInfoList: Sensor mode index 0, knobSetId found 0, knobSetLutIndex 1
BuildSensorModeInfoList: Sensor mode index 1, knobSetId found 1, knobSetLutIndex 2
BuildSensorModeInfoList: Sensor mode index 2, knobSetId found 2, knobSetLutIndex 3
loadIspConfigFromControlKnob: Nito mode. Using cfgData.Common.lensShading
---- Finished loading config data from NITO knobset /var/nvidia/nvcam/settings/zedx_ar0234.nito using knobSetID 0
sensorModeIndex 0 knobSetLutIndex 1 lastKnobSetId -1
[NvCameraIspDriver::initialize] Using CamPG
(Argus) Error 0x00000004: Model Name is NULL (in src/api/CameraDeviceImpl.cpp, function initialize(), line 151)
(Argus) Warning: Unidentified sensor placement (in src/common/ScfTranslate.cpp, function fromScfSensorPlacement(), line 687)
=== nvargus_nvraw[51894]: CameraProvider initialized (0xffffa119ba30)
Number of supported sensor entries 6
Entry Source Mode Uniquename Resolution FR BitDepth Mode
Index Index Index CSI Dyn Type
0 0 0 zedx_ar0234 1920x1200 59 10 10 Bayer
1 0 1 zedx_ar0234 960x 600 120 10 10 Bayer
2 0 2 zedx_ar0234 1920x1080 59 10 10 Bayer
3 1 0 zedx_ar0234 1920x1200 59 10 10 Bayer
4 1 1 zedx_ar0234 960x 600 120 10 10 Bayer
5 1 2 zedx_ar0234 1920x1080 59 10 10 Bayer
=== nvargus_nvraw[51894]: CameraProvider destroyed (0xffffa119ba30)
CaptureService:stop: is requested --------------------------
=== nvargus_nvraw[51894]: Connection closed (FFFFA78088C0)
=== nvargus_nvraw[51894]: Connection cleaned up (FFFFA78088C0)
agi@tegra-ubuntu:~$
