I have met problems with that guide,I can’t see any log from terminal.
I have done the steps according to that website except u-boot source download,I use the L4T R21.4 uboot source code.
Anyone known the reason? please give some advice.I use the R21.4 uboot source code because I can not git the specify source code according to the wiki,if the problem is caused by u-boot source code,who can download it,and send it to my mail. jackwave@126.com. Thanks very much!
When you execute the following command line about tegrarcm, please pay attention to --loadaddr parameter. That should match the u-boot compile option.
By NV release u-boot, that value should be 0x883d8000.
You can check the definition of CONFIG_SPL_TEXT_BASE @ include/configs/tegra124-common.h in u-boot package.
Thanks for your reply, I have tried your advice, but it does not work.
Also, I have get the u-boot source that specified by the website, with this u-boot, everything is OK, ram boot successfully. So, I think u-boot in R21.4 does support download through USB by itself.
u-boot version in R21.4: 2014.10
u-boot version specyfied by the website:2016.01
8192/8192 bytes sent
_out/jetson-tk1/PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.bct sent successfully
sending file: _out/jetson-tk1/u-boot-dtb-tegra.bin
/ 464216/464216 bytes sent
_out/jetson-tk1/u-boot-dtb-tegra.bin sent successfully[/i]
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
egra-pcie: probing port 0, using 2 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
In: serial
Out: serial
Err: serial
Net: RTL8169#0
Warning: RTL8169#0 using MAC address from net device
Hit any key to stop autoboot: 0
Tegra124 (Jetson TK1) # [/i]
