RAS Uncorrectable Error in SNOC, base=0xe011000
Hi
During power on/off stress testing, there were two startup failures. In both cases, the errors occurred during the UEFI stage . The error logs are shown below. Could you please help analyze what might have caused this? (Jetpack version:36.3)
case1:
bootfail.txt (41.4 KB)
bootfail2.txt (44.5 KB)
  Jetson System firmware version root-e539387f8-dirty date 2026-01-26T11:58:51+00:
00
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
......▒▒MmInstallProtocolInterface: 7CE88FB3-4BD7-4679-87A8-A8D8DEE50D2B 0
ERROR:   **************************************
ERROR:   RAS Uncorrectable Error in SNOC, base=0xe011000:
ERROR:          Status = 0xe400030d
ERROR:   SERR = Illegal address (software fault): 0xd
ERROR:          IERR = Carveout Uncorrectable Error: 0x3
ERROR:          MISC0 = 0x2200
ERROR:          MISC1 = 0x41842000000000
ERROR:          MISC2 = 0x0
ERROR:          MISC3 = 0x20
ERROR:          ADDR = 0x8000000472f8d6c0
ERROR:   sdei_dispatch_event returned -1
ERROR:   RAS Uncorrectable Error in ACI, base=0xe01a000:
ERROR:          Status = 0xe8000904
ERROR:   SERR = Assertion failure: 0x4
ERROR:          IERR = FillWrite Error: 0x9
ERROR:          Overflow (there may be more errors) - Uncorrectable
ERROR:   Powering off core
case2:
2026-02-10 17:18:02.775] ERROR:   **************************************
ERROR:   	MISC1 = 0x5c1842000000000
ERROR:   	MISC2 = 0x0
ERROR:   	MISC3 = 0x20
ERROR:   	ADDR = 0x8000000472fe56c0
ERROR:   	Statu
[2026-02-10 17:18:02.836] s = 0xe8000904
Please find the patch at Jetson Linux 36.3 | NVIDIA Developer to see if can help on your case. Thanks
