Hello!
I run plain pipeline for receiving videodata in JetsonNano:
gst-launch-1.0 v4l2src device=/dev/video0 ! “video/x-raw, format=(string)UYVY, width=(int)640, height=480” ! nvvidconv ! “video/x-raw(memory:NVMM), format=(string)I420” ! omxh264enc qp-range=35,35:35,35:-1,-1 ! mpegtsmux ! udpsink clients=192.168.223.103:6000 sync=false
On client side I have this pipeline:
udpsrc name=udpsrc0 ! tsdemux name=tsdemux0 ! queue name=queue0 ! h264parse name=h264parse0 ! avdec_h264 name=avdec_h264-0 ! videoconvert name=videoconvert0 ! appsink name=appsink0
I use CAM_30_CUNANO (https://www.e-consystems.com/nvidia-cameras/jetson-nano-cameras/3mp-mipi-camera.asp) on JetsonNano side.
On JetsonNano side the command “v4l2-ctl --list-formats-ext” outputs:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘UYVY’
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
Interval: Discrete 0.022s (45.000 fps)
Size: Discrete 2304x1536
Interval: Discrete 0.026s (38.000 fps)
So camera has predefined fps (60 fps for 640x480).
My question is:
Is it possible to chage something in pipeline text on JetsonNano side that to take each second, third frame? Because for my case on client side it is need less fps of video stream.
