Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other (2.0.0.11405)
Host Machine Version
other
the solution in that post suggests to compile the kernel, and to follow the compilation step in here ( Compiling the Kernel (Kernel 5.15) | NVIDIA Docs ). However, I don’t have the context of running these steps. Do I run this in my host laptop or do I run it is the container in the host laptop? Does it have anything to do with the SDK Manager? Or do I run these step (compiling kernel steps) on DRIVE device?
Could someone help me by pointing out which is the case?
Thanks for the prompt reply. I have followed the steps and was able to flash the DRIVE OS to the device from the host (inside a docker container in host). The docker container has a signature from docker image list command as nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86 6.0.8.1-0006 d055a29d6559 5 months ago 58GB
What I am not sure what to do next was where do I run the commands provided in the manual webpage (Compling the Kernel (Kernel 5.15) …). Is it inside this docker container? If so, what is the $NV_WORKSPACE?
So far I have finished all the steps in here with the necessary modification from another thread. Now I am looking at step 14 and did not know where the SDK Bootburn tool is. Is it inside the same docker container? If so, is there an instruction on how to use this tool to properly burn the image I just built?
docker: Error response from daemon: failed to create endpoint dazzling_black on network bridge: failed to add the host (veth6be7bf3) <=> sandbox (vethb5351de) pair interfaces: operation not supported.
