Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
we face the same issues regarding Docker as described in this post:
Unfortunately the topic is closed.
We followed the provided solution there, and both compiling the kernel and flashing the Orin device (via docker on host with flash.py) have been successful.
After restarting and also reinstalling Docker, the error message still persists.
Is there anything obvious we are still missing and/or can you please describe the exact steps required before or after compiling/flashing to enable Docker support again?
Dear @AdamBalazsVay,
After reflash, Do you see issue with Keyboard/mouse control and target is accessed via serial console? Please see [BUG] Run Docker in 6.8.0.1 failed or you notice a different issue?
It is the reflash step I struggle with, so I could not figure out the way how to use the SDK Bootburn tool to flash the device with the custom kernel. What parameters do I need to specify there, how can I specify the new kernel to flash? It would be nice to have a step by step guide what commands I need to execute, like in the other steps of the kernel build guide. Besides, in [BUG] failed to start docker container in orin target with error: failed to create endpoint on network bridge, operation not supported - #6 by SivaRamaKrishnaNV we build a non-production kernel ( defconfig and not tegra_prod_defconfig), so it could not be used in our production environment. Could you please give us an update how nvidia plans to fix this in a proper, production ready way and what the timeline is? We are blocked now by this issue.
May I know what command you have used to flash?
Did you use the below commands to flash the target?
make/bind_partitions -b <board config> linux
#put the board in recovery mode from aurix console
tools/flashtools/bootburn/bootburn.py -b <board config> -B qspi
##put the board in normal mode form aurix console
I haven’t used any command yet, I wanted to figure out how to do it first :) I will check the command you have shared. In the case of Orin dev boards the commands look like the following, right?
make/bind_partitions -b p3710-10-a01 linux
tools/flashtools/bootburn/bootburn.py -b p3710-10-a01 -B qspi
I tried to open a bug ticket on your support page but I got redirected to this forum again.
While we check if the workaround you proposed (flashing a custom kernel) could unblock us for a short term, we would like to get an overview about the exact way and timeline of the proper fix from NVIDIA (not a workaround).
I would like to get a confirmation, that it is indeed a bug and will be fixed in a future release (this article e.g. explicitly mentions that running docker containers are supported out of the box on NVIDIA DRIVE AGX Orin). A binary patch for the current version would be highly appreciated as well. Currently our ongoing Orin transition is blocked because of this bug, as we deploy our code as a docker image we run on the devices.
I can confirm, that with compiling and deploying a custom kernel with general → namespaces support and with making device driver → network device → veth builtin instead of loadable, we can run docker containers again.
Unfortunately it is not a production ready solution, just a workaround, as we are compiling a kernel with non-prod flags. Please let us know about the timeline of a proper, binary fix.
As I see DriveOS 6.0.9 got released, but I don’t have access yet to the release notes. Do you know if we can expect the new release to fix this issue?
