Hi Team,
is it possible, to record 2 different cameras in Python, one connected to CAM0 and one to CAM1 at the same time, assuming the Jetson Orin Nano can handle the datarate and cpu-load that is required?
Best Regards
Tim
Hi Team,
Best Regards
Tim
Orin Nano does not have hardware encoder, so it depends on the resolution. Single 1080p30 should be fine for using software encoder. If you have two sources, may try to encode 2x 720p30.
