RED HAT Problem Compile Driver For 330M NVIDIA-Linux-x86_64-340.108.run
my Log Error:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Dec 9 14:05:24 2020
installer version: 340.108
PATH: /usr/local/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/var/lib/snapd/snap/bin:/ro$
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
→ Tagging shared libraries with chcon -t textrel_shlib_t.
→ License accepted.
→ Installing NVIDIA driver version 340.108.
→ Performing CC sanity check with CC=“/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.18.0-240.1.1.el8_3.x86_64/source’
→ Kernel output path: ‘/lib/modules/4.18.0-240.1.1.el8_3.x86_64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.-> Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /bin/make clean’…
→ Building NVIDIA kernel module:
executing: 'cd ./kernel; /bin/make module SYSSRC=/lib/modules/4.18.0-240.1.1$
NVIDIA: calling KBUILD…
make[1]: Entering directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
/bin/make -C /lib/modules/4.18.0-240.1.1.el8_3.x86_64/build KBUILD_SRC=/usr/$
-f /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/Makefile modules
make[2]: Entering directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
→ Performing Xen check.
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( $
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.";
echo >&2 " include/generated/autoconf.h or include/config/auto.conf $
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix$
echo >&2 ;
/bin/false)
mkdir -p /tmp/selfgz29978/NVIDIA-Linux-x86_64-340.108/kernel/.tmp_versions ;$
/bin/make -f /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/scripts/Makefile.b$
(cat /dev/null; echo kernel//tmp/selfgz29978/NVIDIA-Linux-x86_64-340.108/k$
final log
nv_drm_pci_exit(&nv_drm_driver, pci_driver);
cc1: some warnings being treated as errors
make[3]: *** [/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/scripts/Makefile.$
make[2]: *** [/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/Makefile:1544: _m$
make[2]: Leaving directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
make[1]: *** [Makefile:157: sub-make] Error 2
make[1]: Leaving directory ‘/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64’
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make: *** [Makefile:197: nvidia.ko] Error 1
→ Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer$
a use this istruction.
precompilated driver for 330M a Not Find Kernel uname -r = 4.18.0-240.1.1.el8_3.x86_64
dkms installed and error compile.
… Part de log.
: comparaison d’expressions entières de types signés différents: « long int » et « long unsigned int » [-Wsign-compare]
if (to_set->tv_nsec > NSEC_PER_SEC - TIME_SET_NSEC_FUZZ) {
/var/lib/dkms/nvidia/340.108/build/nv-drm.c: Dans la fonction « nv_drm_init »:
/var/lib/dkms/nvidia/340.108/build/nv-drm.c:54:25: error: déclaration implicite de la fonction « drm_pci_init »; vouliez-vous utiliser « drm_mm_init » ? [-Werror=implicit-function-declaration]
#define nv_drm_pci_init drm_pci_init
/var/lib/dkms/nvidia/340.108/build/nv-drm.c:214:11: note: dans l’expansion de la macro « nv_drm_pci_init »
ret = nv_drm_pci_init(&nv_drm_driver, pci_driver);
/var/lib/dkms/nvidia/340.108/build/nv-drm.c: Dans la fonction « nv_drm_exit »:
/var/lib/dkms/nvidia/340.108/build/nv-drm.c:55:25: error: déclaration implicite de la fonction « drm_pci_exit »; vouliez-vous utiliser « drm_dev_exit » ? [-Werror=implicit-function-declaration]
#define nv_drm_pci_exit drm_pci_exit
/var/lib/dkms/nvidia/340.108/build/nv-drm.c:224:5: note: dans l’expansion de la macro « nv_drm_pci_exit »
cc1 : certains avertissements sont traités comme des erreurs
make[3]: *** [/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/scripts/Makefile.build:316: /var/lib/dkms/nvidia/340.108/build/nv-drm.o] Error 1
make[2]: *** [/usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64/Makefile:1544: module/var/lib/dkms/nvidia/340.108/build] Error 2
make[2] : on quitte le répertoire « /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64 »
make[1] : on quitte le répertoire « /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64 »
GNU nano 2.9.8 /var/log/nvidia-installer.log
Help Me For Compile A Driver Plese…
