您好!我高德软件有限公司研发人员,有如下需求:双目摄像头,1080P@30pfs,视场角120~140,相机基线60CM。应用场景时车载双目,需要视频同步,相机贴装在前挡风玻璃处,相机之间距离60厘米以上。请您推荐一下实现方案(之前考虑直接用CSI接口相机,但后来从网上资料获悉,CSI相机接口只能支持10CM左右距离,达不到要求)
Hi zhuguohong.zgh
Welcome to Jetson & Embedded Systems developer forum.
Please create the topic and issue in English manner.
Other developers can understand your issue and to share their experience with you quickly if they ever met similar issue in design stage.
And then other users could be leverage from this issue to get benefits.
Regarding camera solutions, please find those information from [url]Jetson FAQ | NVIDIA Developer
Thank you.
There are the following requirements: binocular camera, 1080P@30pfs, field of view angle 120 ~140,Camera baseline 60cm.Application scene is vehicle,Video synchronization required,Camera mounted on front windshield. Please recommend the implementation scheme.(有如下需求:双目摄像头,1080P@30pfs,视场角120~140,相机基线60CM。应用场景时车载双目,需要视频同步,相机贴装在前挡风玻璃处,相机之间距离60厘米以上。请您推荐一下实现方案(之前考虑直接用CSI接口相机,但后来从网上资料获悉,CSI相机接口只能支持10CM左右距离,达不到要求))
We will suggest you to try our TRICamera product e-CAM130_TRICUTX2. It will provide synchronous output at 1080p and 4K @30fps. Please refer the below link to get more information:
[url]https://www.e-consystems.com/three-synchronized-4k-cameras-for-nvidia-jetson-tx2.asp[/url]
