Description
I have tried to run a Reid.caffemodel on trtexec to save engine but I got an error as below.Kindly help .
Environment
TensorRT Version: 7.0
GPU Type: T4
Nvidia Driver Version: 440
CUDA Version: 10.2
CUDNN Version:
Operating System + Version: 18.04
e]0;root@GokuDDG-B85M-D3H: /usr/src/tensorrt/binae[01;32mroot@GokuDDG-B85M-D3He[00m:e[01;34m/usr/src/tensorrt/bine[00m# sudo ./trtexec --deploy=deploy.prototxt --model=reid.caffemodel --output=View_1 --batch=4 --saveEngine=reid.trt e[1Pe[1@1e[1@6
&&&& RUNNING TensorRT.trtexec # ./trtexec --deploy=deploy.prototxt --model=reid.caffemodel --output=View_1 --batch=16 --saveEngine=reid.trt
[07/03/2020-10:32:38] [I] === Model Options ===
[07/03/2020-10:32:38] [I] Format: Caffe
[07/03/2020-10:32:38] [I] Model: reid.caffemodel
[07/03/2020-10:32:38] [I] Prototxt: deploy.prototxt
[07/03/2020-10:32:38] [I] Output: View_1
[07/03/2020-10:32:38] [I] === Build Options ===
[07/03/2020-10:32:38] [I] Max batch: 16
[07/03/2020-10:32:38] [I] Workspace: 16 MB
[07/03/2020-10:32:38] [I] minTiming: 1
[07/03/2020-10:32:38] [I] avgTiming: 8
[07/03/2020-10:32:38] [I] Precision: FP32
[07/03/2020-10:32:38] [I] Calibration:
[07/03/2020-10:32:38] [I] Safe mode: Disabled
[07/03/2020-10:32:38] [I] Save engine: reid.trt
[07/03/2020-10:32:38] [I] Load engine:
[07/03/2020-10:32:38] [I] Inputs format: fp32:CHW
[07/03/2020-10:32:38] [I] Outputs format: fp32:CHW
[07/03/2020-10:32:38] [I] Input build shapes: model
[07/03/2020-10:32:38] [I] === System Options ===
[07/03/2020-10:32:38] [I] Device: 0
[07/03/2020-10:32:38] [I] DLACore:
[07/03/2020-10:32:38] [I] Plugins:
[07/03/2020-10:32:38] [I] === Inference Options ===
[07/03/2020-10:32:38] [I] Batch: 16
[07/03/2020-10:32:38] [I] Iterations: 10
[07/03/2020-10:32:38] [I] Duration: 3s (+ 200ms warm up)
[07/03/2020-10:32:38] [I] Sleep time: 0ms
[07/03/2020-10:32:38] [I] Streams: 1
[07/03/2020-10:32:38] [I] ExposeDMA: Disabled
[07/03/2020-10:32:38] [I] Spin-wait: Disabled
[07/03/2020-10:32:38] [I] Multithreading: Disabled
[07/03/2020-10:32:38] [I] CUDA Graph: Disabled
[07/03/2020-10:32:38] [I] Skip inference: Disabled
[07/03/2020-10:32:38] [I] Input inference shapes: model
[07/03/2020-10:32:38] [I] Inputs:
[07/03/2020-10:32:38] [I] === Reporting Options ===
[07/03/2020-10:32:38] [I] Verbose: Disabled
[07/03/2020-10:32:38] [I] Averages: 10 inferences
[07/03/2020-10:32:38] [I] Percentile: 99
[07/03/2020-10:32:38] [I] Dump output: Disabled
[07/03/2020-10:32:38] [I] Profile: Disabled
[07/03/2020-10:32:38] [I] Export timing to JSON file:
[07/03/2020-10:32:38] [I] Export output to JSON file:
[07/03/2020-10:32:38] [I] Export profile to JSON file:
Weights for layer ConvNd_1 doesn’t exist
[07/03/2020-10:32:39] [E] [TRT] CaffeParser: ERROR: Attempting to access NULL weights
[07/03/2020-10:32:39] [E] [TRT] ConvNd_1: second input must be provided if kernel weights are empty.
[07/03/2020-10:32:39] [E] [TRT] ConvNd_1: kernel weights has count 0 but 9408 was expected
[07/03/2020-10:32:39] [E] [TRT] ConvNd_1: count of 0 weights in kernel, but kernel dimensions (7,7) with 3 input channels, 64 output channels and 1 groups were specified. Expected Weights count is 3 * 7*7 * 64 / 1 = 9408
trtexec: ./parserHelper.h:99: nvinfer1::DimsCHW parserhelper::getCHW(const nvinfer1::Dims&): Assertion `d.nbDims >= 3’ failed.
Aborted
e]0;root@GokuDDG-B85M-D3H: /usr/src/tensorrt/binae[01;32mroot@GokuDDG-B85M-D3He[00m:e[01;34m/usr/src/tensorrt/bine[00m# exit
Script done on 2020-07-03 10:32:44+0530
