Remote Display not loading with GeForce GT 710
I am having issues with my Linux Mint/Ubuntu system to properly display via a remote desktop connection - the system is using llvmpipe when logged in via remote desktop connection, but properly configures when connected to the system locally/in person. System details:
Linux Mint 19.2, Ubuntu 18.04
Kernel version: 4.15.0-189-generic x86_64
GPU: GeForce GT 710
Nvidia driver version: 470.141.03
Remote connection via XRDP
The nvidia-smi recognizes the GPU and does not return any errors.
Symptoms of the issue:
  • The physical/in person computer display works as expected. The issues described below are not present with the in person/physical computer display and only affect the remote connection display.
  • nvidia-settings outputs ‘ERROR: Unable to load info from any available system.’ The application attempts to open but simply creates a blank window.
  • data visualization program “Paraview” does not display information, although by left/right clicking on the display, the program provides dropdown menus indicating that the program has loaded but is not displaying the program information.
  • prime-select nvidia indicates that the nvidia profile is already set
  • inxi -G indicates that the renderer is using llvm. inxi -Gxx:
Graphics:
  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
  driver: nvidia v: 470.141.03 bus ID: 81:00.0 chip ID: 10de:128b
  Display: server: X.Org 1.19.6 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa compositor: marco
  resolution: 3000x2000~50Hz
  OpenGL: renderer: llvmpipe (LLVM 10.0.0 256 bits) v: 3.3 Mesa 20.0.8
  compat-v: 3.1 direct render: Yes
I have already tried version 390 and the same symptoms were present. Attached is the report log when run via the REMOTE connection. I appreciate any help with identifying and fixing this issue as I’m not sure what to do next. Thanks.
nvidia-bug-report-REMOTE.log.gz (1.1 MB)
Thanks generix. Based on you linking that post, are you saying that there is no solution for this issue? I tried some of the suggestions in that post and other that were linked to that post and have not come up with a solution.
Would this solution linked below that you previously provided be appropriate in my situation?
See this for a simple solution:
https://forums.developer.nvidia.com/t/opengl-uses-the-mesa-implementation-not-the-nvidia/219073/10?u=generix
Please read the whole thread to get the picture.
Thanks generix. I appreciate the direction and I was able to implement an adequate solution using x11vnc. For the benefit of others who may come across this post, this was my solution method:
  1. Understand that Nvidia graphics card seem to present issues with allowing remote connections to properly display on the remote connection when using a remote X display (as in with the built in Windows Remote Desktop Connection software). As a result, assuming the local X display is working as intended, the local X display must be forwarded to the remote client.
  2. The following links were helpful in setting things up. I used x11vnc and openssh-server on Ubuntu; Putty and TightVNC on Windows 10.
    Original author of x11vnc: https://wiki.archlinux.org/title/X11vnc
    Partially helpful directions on installing x11vnc: https://github.com/LibVNC/x11vnc
    General directions on overall process: https://tombuntu.com/index.php/2007/06/27/remote-access-from-windows-x11vnc/
    General directions on overall process: http://klikgss.com/blog/2021/11/25/how-to-tunnel-vnc-connection-through-ssh-using-putty/
Here are the steps that I took at a high level - see the links above for more detail:
  • Installed x11vnc and openssh-server on Ubuntu machine
  • Installed TightVNC on Windows machine
  • Locally log in to Ubuntu machine prior to attempting a remote connection
  • Configure Putty with SSH settings
  • Within Putty terminal, load x11vnc
  • Configure TightVNC with setup SSH settings
  • Input x11vnc password to login to TightVNC
