Rep.create.group not working
Hi, I have two folder paths: one for “dolls” and one for “hose”. I need to instantiate the two groups seperatly in order to assign semantics but then I need to group them together in order to proparly scatter all objects on the same plane. This is my code:
HOSE_ON_GROUND_ASSETS_DIR = "C:/Users/dsiss/Desktop/Synthia-LFS/Omniverse/randomization_assets/water_hose/rolled_on_ground"
DOLLS_ASSETS_DIR = "C:/Users/dsiss/Desktop/Synthia-LFS/Omniverse/randomization_assets/toys/dolls"
plane_path = "/World/Plane"
with rep.new_layer():
	traversable_plane = rep.get.prim_at_path(plane_path)
	hoses_usd = rep.utils.get_usd_files(HOSE_ON_GROUND_ASSETS_DIR)
	hoses_prims = rep.randomizer.instantiate(hoses_usd, size=5, use_cache = False)
	with rep.utils.sequential():
	    with hoses_prims:
	        rep.modify.semantics(semantics = [("class", "hose")])
	dolls_usd = rep.utils.get_usd_files(DOLLS_ASSETS_DIR)
	dolls_prims = rep.randomizer.instantiate(dolls_usd, size=5, use_cache = False)
	    with dolls_prims:
	        rep.modify.semantics(semantics = [("class", "toy")])
	group = rep.create.group(semantics=[("class", "hose"), ("class", "toy")])
		with group:
			rep.randomizer.scatter_2d(traversable_plane, check_for_collisions=True)
the line
does not work.
get.prims does not work eaither.
How can I group these prims after instantiating (or before) while still assigning different semantics?
Thank you
Hi there,
the semantics argument will apply the given semantics to the items to be grouped:
cones = [rep.create.cone() for _ in range(100)]
group = rep.create.group(cones, semantics=[("class", "cone")])
you could use rep.get.prims for this:
cubes = rep.get.prims(semantics=[("class", "cube")])
Best,
Change it to
group = rep.create.group([hoses_prims, dolls_prims])
I believe what is happening in your original script is that rep.modify.semantics and rep.create.group are essentially evaluated at the same time (since there is no clear dependency on other objects in the code). So when rep.create.group is being evaluated, there are no prims with semantics=[("class", "hose"), ("class", "toy")].
By writing it as group = rep.create.group([hoses_prims, dolls_prims])
  1. You are using the exact prims you instantiated earlier
  2. By using variables from earlier in the script, a dependency is created and those are evaluated first
@dennis.lynch Hi, I tried this too but it does not work.
So this is my code:
HOSE_ON_GROUND_ASSETS_DIR = "C:/Users/dsiss/Desktop/synthia-LFS/Omniverse/randomization_assets/water_hose/rolled_on_ground"
DOLLS_ASSETS_DIR = "C:/Users/dsiss/Desktop/synthia-LFS/Omniverse/randomization_assets/toys/dolls"
    hoses_prims = rep.randomizer.instantiate(hoses_usd, size=4, with_replacements = False, use_cache = False)
        with hoses_prims:
    dolls_prims = rep.randomizer.instantiate(dolls_usd, size=4, with_replacements = False, use_cache = False)
        with dolls_prims:
    group = rep.create.group(items=[hoses_prims, dolls_prims])
        with group:
But it seems that only the hose prims are properly scattered, meaning that the group only consists of hoses_prims. If i switch the order of the items list:
group = rep.create.group(items=[dolls_prims, hoses_prims])
Then same is still true, only the hose prims are scattered.
Hello again,
So I’ve verified a bug where scatter_2d does not work with prims created with instantiate
However, there seems to be a workaround by replacing instantiate with create.from_usd
My simple test code:
# IsaacSim default is "Z", Code is "Y"
rep.settings.set_stage_up_axis("Z")
rep.settings.set_stage_meters_per_unit(0.01)
SURFACE = (
    "omniverse://localhost/NVIDIA/Assets/Scenes/Templates/Basic/display_riser.usd"
ENVS = "omniverse://localhost/NVIDIA/Assets/Scenes/Templates/Interior/ZetCG_ExhibitionHall.usd"
FRUIT_PROPS = {
    "apple": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Fruit/Apple.usd",
    "avocado": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Fruit/Avocado01.usd",
    "kiwi": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Fruit/Kiwi01.usd",
    "lime": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Fruit/Lime01.usd",
    "lychee": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Fruit/Lychee01.usd",
    "pomegranate": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Fruit/Pomegranate01.usd",
    "onion": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Vegetables/RedOnion.usd",
    "strawberry": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Food/Berries/strawberry.usd",
    "lemon": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Decor/Tchotchkes/Lemon_01.usd",
    "orange": "omniverse://localhost/NVIDIA/Assets/ArchVis/Residential/Decor/Tchotchkes/Orange_01.usd",
FRUIT_USD_LIST = list(FRUIT_PROPS.values())
    surface = rep.create.disk(scale=(5,5,5))
    apples = rep.create.from_usd(FRUIT_USD_LIST[0], count=10)
    oranges = rep.create.from_usd(FRUIT_USD_LIST[-1], count=10)
    fruit_group = rep.create.group(items=[apples, oranges])
    with rep.trigger.on_frame(max_execs=10):
        with fruit_group:
            rep.randomizer.scatter_2d(surface, check_for_collisions=False)
Modifying your code
    hoses_prims = rep.create.from_usd(hoses_usd, count=4, semantics=[("class", "hose")])
    dolls_prims = rep.create.from_usd(dolls_usd, count=4, semantics=[("class", "toy")])
        with group:
You might need to change this a bit to match some of the “random selection” of instantiate by using distribution.choice on the prim paths
@dennis.lynch Thank you for this work around but it wont work since create.from_usd expects a path to a single usd but my path is a path to a directory.
I tried using choice:
    hoses_usds = rep.utils.get_usd_files(HOSE_ON_GROUND_ASSETS_DIR)
    hose = rep.distribution.choice(hoses_usds)
    with hose:
        rep.create.from_usd(semantics=[("class", "hose")])
But this does not work either. Using create.from_dir is also not an option as it selects all the usds in that directory.
@dennis.lynch
this does not work either:
    rep.create.from_usd(hose, semantics=[("class", "hose")])
any idea why?
this code works (i can segment the different prims and scatter them). But I need to randomly select files from the directory (and not all the usd files)
    hose_prims = rep.create.from_dir(HOSE_ON_GROUND_ASSETS_DIR, recursive = True, semantics=[("class", "hose")])
    robot = rep.get.prim_at_path(robot_path)
    dolls_prims = rep.create.from_dir(DOLLS_ASSETS_DIR, recursive = True, semantics=[("class", "doll")])
    group = rep.create.group([hose_prims, dolls_prims])
    with group:
        rep.randomizer.scatter_2d(traversable_plane, no_coll_prims= [robot], check_for_collisions=True)
        rep.physics.collider()
        rep.modify.pose(rotation =rep.distribution.uniform((0,0,0), (0,0,180)))
You would do something like this to create multiple USD prims from a directory path and place them into a group object:
usds = rep.utils.get_usd_files(DIRECTORY_PATH)
object_list = []
for usd in usds:
    obj = rep.create.from_usd(usd), semantics=[("class", "thing")])
    object_list.append(obj)
object_group = rep.create.group(object_list)
To do a random selection from the directory:
import random
object_list = []
for usd in usds:
    obj = rep.create.from_usd(random.choice(usd)), semantics=[("class", "thing")])
