Hello!
This is Aekavich A. I am installing JetPack into NVIDIA Jetson Orin Nano Super Dev Kit (8GB).
As I am beginner to the GPU and JetPack installation, I need your prompt support to solve my JetPack installation issues:
Below explanation includes the details of issue and request to you as follows:
Observed Issues: Please refer to attached image 1,2, and 3.
[File name : Image 1]
When I check for GPU information by running “nvidia-smi” in the command line, the result shows “N/A” for all metrics such as Persistence-M, Bus-Id, etc. and Memory-Usage value is “Not Supported”. My understanding is it seems like JetPack installation has some issues that computer can’t grasp the data of GPU (Orin).
By running “cat /etc/nv_tegra_release”, I can get the current/latest JetPack installation, which is R36 (release) REVISION: 4.3 or JetPack 6.2 Linux 36.4.3
On the other hand, by running “sudo apt-cache show nvidia-jetpack | grep “Version””, I can get that there are 2 different versions of JetPack in this computer:
Version: 6.2+b77 → JetPack 6.2 Linux L4T 36.4.3
Version: 6.1+b123 → JetPack 6.1 Linux L4T 36.4.0
[File name : Image 2]
- By running “sudo apt-cache show nvidia-jetpack”, I can get more details of 2 JetPack versions installed in this computer (Just detailed information of the above 3)
[File name : Image 3]
- By running “apt-cache policy nvidia-jetpack”, I can get information about Installed version and 2 Nvidia-JetPack candidates.
My suspicious actions:
I run “sudo apt update” and “sudo apt full-upgrade -y” . After that, 2 JetPack versions are co-existed in the computer.
I run “sudo apt install nvidia-jetpack=6.2+b77”
because running “sudo apt install nvidia-jetpack=6.1+b123” causes error message “unmet dependencies” and “Unable to correct problems, you have held broken packages” → Refer to Image4 and 5 [File name : Image 4.png and Image5.png]
[File name : Image 4]
[File name : Image 5]
Question to be requested for your support :
Is GPU JetPack successfully installed? Why are GPU information almost N/A?
Do 2 detected versions(JetPack 6.1 & 6.2) matter incomplete JetPack installation (i.e. conflict packages)? If yes, how to solve the issue?
Your prompt response is highly appreciated.
Best Regards,
Aekavich A.
