Jetson Orin NX can't install jetpack
I installed the desktop-less version of ubuntu-server22.04 on my Jetson Orin NX and copied nvidia-l4t-apt-source.list, jetson-ota-public.asc to the appropriate folders in the /etc/apt directory, and executed the command sudo apt update and sudo apt install nvidia-jetpack failed, is there any way to install jetpack?
developer@ubuntu-server:/etc/apt/trusted.gpg.d$ sudo apt install nvidia-jetpack
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-jetpack-dev : Depends: nvidia-cuda-dev (= 6.1+b123) but 11.5.1-1ubuntu1 is to be installed
E: Unable to correct problems, you have held broken packages.
Could you share the results with below commands
cat /etc/nv_tegra_release
developer@ubuntu-server:~$ cat /etc/nv_tegra_release
R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
Please read it. Thank you.
Thanks for your information
Also share this result
cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
developer@ubuntu-server:~$ cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
# SPDX-FileCopyrightText: Copyright (c) 2019-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
deb https://repo.download.nvidia.com/jetson/common r36.4 main
deb https://repo.download.nvidia.com/jetson/t234 r36.4 main
deb https://repo.download.nvidia.com/jetson/ffmpeg r36.4 main
something wrong with your environment.
For example, your jtop log show your L4T is missing
Could you use the sdk manager to reflash your device with clean environment?
If you want to install desktopless.
Please refer to official doc to build it
https://docs.nvidia.com/jetson/archives/r36.4/DeveloperGuide/SD/RootFileSystem.html#minimal-flavor-root-file-system
I rebooted and found that jetpack was installed but tools like cuda were not detected, so I installed cuda, cudnn and opencv separately and jtop was able to detect,but I could not see the list of running processes and resources consumed in jtop, what could be the reason? How to fix it?
If the question is not related to original topic, please file a new one.
Okay, sorry about that.
In the end, I installed cuda, cudnn, and opencv separately and it didn’t affect how my program ran.
Refer to the following address for the installation of cuda and cudnn:
