I use Jetson Orin NX 16GB modules and the Jetson Xavier NX Developer Kit carrier board.
I modify nvbackup_partitions.sh and nvrestore_partitions.sh to make it work for NVMe SSD. I modify those script by replacing all mmcblk0 reference with nvme0n1.
Now I want to swipe this backup into my homemade carrier board, which is using an sd card for storage, but failed.
The package used is Jetson_Linux_R35.2.1_aarch64.tbz2.
orin-nx-overlay-35.2.1.tbz2, Tegra_Linux_Sample-Root-Filesystem_R35.2.1_aarch64.tbz2
Commands used:
sudo ./tools/backup_restore/l4t_backup_restore.sh -b p3768-0000+p3767-0000
Terminal print:
[ 0.1395 ] Added binary blob_tegra234-p3767-0000-p3768-0000-a0.dtb of size 341710
[ 0.1867 ] tegrarcm_v2 --instance 3-9 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.1874 ] BL: version 0.28.0.0-t234-54845784-ec016368 last_boot_error: 0
[ 0.2775 ] Sending bct_mem
[ 0.2931 ] Sending blob
[ 3.1279 ] RCM-boot started
/data/jetson/orin/Linux_for_Tegra
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/data/work/strun".
Assuming default behaviour ('no_subtree_check').
NOTE: this default has changed since nfs-utils version 1.0.x
exportfs: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/data/work/05.zx".
Which scripts should I change?
log.txt (80.6 KB)
