Hi Nvidia,
Jetpack: 6.0 (R36.3)
PHY: RTL8211
1. Hardware:
2. Device Tree Configuration:
ethernet@2310000 {
status = "okay";
phy-mode = "rgmii-id";
phy-handle = <&rgmii_phy>;
nvidia,phy-reset-gpio = <&gpio TEGRA234_MAIN_GPIO(Y, 1) 0>;
nvidia,mac-addr-idx = <1>;
nvidia,max-platform-mtu = <16383>;
nvidia,mdio_addr = <1>;
mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
rgmii_phy: phy@1 {
reg = <1>;
nvidia,phy-rst-pdelay-msec = <224>; /* msec */
nvidia,phy-rst-duration-usec = <20000>; /* usec */
//interrupt-parent = <&gpio>;
//interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
3. Pinmux Configuration:
eqos_txc_pe0 {
nvidia,pins = "eqos_txc_pe0";
nvidia,function = "eqos";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
eqos_td0_pe1 {
nvidia,pins = "eqos_td0_pe1";
eqos_td1_pe2 {
nvidia,pins = "eqos_td1_pe2";
eqos_td2_pe3 {
nvidia,pins = "eqos_td2_pe3";
eqos_td3_pe4 {
nvidia,pins = "eqos_td3_pe4";
eqos_tx_ctl_pe5 {
nvidia,pins = "eqos_tx_ctl_pe5";
eqos_rd0_pe6 {
nvidia,pins = "eqos_rd0_pe6";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
eqos_rd1_pe7 {
nvidia,pins = "eqos_rd1_pe7";
eqos_rd2_pf0 {
nvidia,pins = "eqos_rd2_pf0";
eqos_rd3_pf1 {
nvidia,pins = "eqos_rd3_pf1";
eqos_rx_ctl_pf2 {
nvidia,pins = "eqos_rx_ctl_pf2";
eqos_rxc_pf3 {
nvidia,pins = "eqos_rxc_pf3";
eqos_sma_mdio_pf4 {
nvidia,pins = "eqos_sma_mdio_pf4";
eqos_sma_mdc_pf5 {
nvidia,pins = "eqos_sma_mdc_pf5";
4. Kernel Log Errors:
[ 10.245203] nvethernet 2310000.ethernet: Adding to iommu group 54
[ 10.251994] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 10.252001] nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[ 10.252003] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 10.505274] nvethernet 2310000.ethernet: Ethernet MAC address: 3c:6d:66:63:c6:6a
[ 10.568332] nvethernet 2310000.ethernet: Macsec not enabled
[ 10.568336] nvethernet 2310000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 10.577539] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 11.956787] mdio_bus 2310000.ethernet: MDIO device at address 1 is missing.
[ 11.956800] nvethernet 2310000.ethernet: failed to connect PHY
[ 11.956806] net eth0: ether_open: Cannot attach to PHY (error: -19)
