Hi, I want to use realtek8211FS using rgmii.
However, even if i follow the guide, I cannot use ethernet.
Pinmux and gpio dtsi
Orin-jetson_agx_orin-pinmux.txt (65.7 KB)
Orin-jetson_agx_orin-gpio-default.txt (4.8 KB)
ethernet@6810000 disable
ethernet@2130000 enable and configuration
dmesg
dmesg.txt (68.6 KB)
/sys/kernel/debug/gpio
ifconfig
ifconfig eth0 up
Does “cat /proc/interrupts | grep eth” give you any interrupt increase when you up/down the interfaces?
Could you share the result of your cat /proc/interrupts first? No grep, just full result.
here is my /proc/interrupts log.
interrupts.txt (20.4 KB)
Please also dump all these registers which is for pinmux
busybox devmem 0x02434070:
busybox devmem 0x02434078:
busybox devmem 0x02445058:
busybox devmem 0x02445018:
busybox devmem 0x02445010:
busybox devmem 0x02445008:
busybox devmem 0x02445000:
busybox devmem 0x02445068:
busybox devmem 0x02445040:
busybox devmem 0x02445030:
busybox devmem 0x02445028:
busybox devmem 0x02445020:
busybox devmem 0x02445070:
busybox devmem 0x02445060:
busybox devmem 0x02445038:
busybox devmem 0x02445048:
busybox devmem 0x02445050
Here is pinmux dump log.
0x00000040
0x00000000
0x00002408
0x00002408
0x00002408
0x00002408
0x00002408
0x00002408
0x00002458
0x00002458
0x00002458
0x00002458
0x00002458
0x00002458
0x00002440
0x00002408
0x00002000
please remove TEGRA234_MAIN_GPIO(G, 5) from gpio-output-low in your gpio dtsi.
Are you talking about gpio-default dtsi?
here is my gpio-output-low
but, The busybox devmem value is the same as before.
I didn’t share the GPIO register, only the pinctrl reg.
GPIO reg:
0x022140a0 for GPIO G,5
0x02214080 for GPIO G,4
Is this the reason why gpio-output-low appears?
I don’t know what does your question mean. PInmux file won’t look into to your kernel dts file and create different results…
The reason gpio-output-low is there is because your configuration in pinmux spreadsheet.
Ah, I thought the devmem value was changed by pinmux settings.
What should I do now?
Pinmux register will be affected by pinmux setting… And GPIO register will be affected by pinmux and also driver during runtime…
I shared you the GPIO register address… please read…
I’m sorry.
Here is my busybox devmem.
The value is correct.
Please ask your hardware engineer to help check the PHY comes out of reset mode and is in a ready state when the PHY reset GPIO is toggled.
Is it true that the jetson agx orin devkit board is compatible with RTL8211FS?
No, I don’t know whether it is compatible with it or not. This was not validated.
