ORIN RGMII can not work(phy 88e1512)
Hello nv team:
We designed a carrier board for Orin.The RGMII interface is used,and the PHY chip is 88E1512.
We did the following:
1 Modify the dts file to generate the dtb file,and replace the dtb file.
→ Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb
tegra234-p3701-0000-p3737-0000.dts (4.8 KB)
kernel_tegra234-p3701-0000-p3737-0000.dts (521.9 KB)(from dtb)
2 Generate Pinmux.dtsi and gpio.dtsi from Pinmux_Config_Template,and replace the dtsi file.
→Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi
Orin-jetson_agx_orin-pinmux.dtsi (64.6 KB)
→Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpio-p3701-0000.dtsi
tegra234-mb1-bct-gpio-p3701-0000.dtsi (3.9 KB)
→Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000.dtsi
tegra234-mb1-bct-padvoltage-p3701-0000.dtsi (1.4 KB)
3 sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
But the interface is not working.We double-checked the pinmux file but found no problems comparing Adaptation and Bringup for Jetson AGX Orin.Is there anything wrong with the dtb we modified?
Please help us,thanks.
debug-uart.log (96.8 KB)
please follow the document. rel-35.1 document has something wrong so you should follow rel-35.2 doc.
https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=rgmii#for-rgmii
I referred to this document, $ should be 5.
I also referred to the pdf document.
I also referred to these posts.
RGMII Enabling Problem - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
Jetson ORIN: RGMII can’t send data - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
In contrast, I found no errors.
Is there an error with my dts file? Can you confirm this for me? Thanks!
The error I mean in previous comments are the pinmux typo in old document. Not device tree.
I compared the documents repeatedly.No discrepancies were found.
My pinmux.
eqos_txc_pe0 {
nvidia,pins = “eqos_txc_pe0”;
nvidia,function = “eqos”;
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
		eqos_td0_pe1 {
			nvidia,pins = "eqos_td0_pe1";
			nvidia,function = "eqos";
		eqos_td1_pe2 {
			nvidia,pins = "eqos_td1_pe2";
		eqos_td2_pe3 {
			nvidia,pins = "eqos_td2_pe3";
		eqos_td3_pe4 {
			nvidia,pins = "eqos_td3_pe4";
		eqos_tx_ctl_pe5 {
			nvidia,pins = "eqos_tx_ctl_pe5";
		eqos_rd0_pe6 {
			nvidia,pins = "eqos_rd0_pe6";
			nvidia,pull = <TEGRA_PIN_PULL_UP>;
			nvidia,tristate = <TEGRA_PIN_ENABLE>;
			nvidia,enable-input = <TEGRA_PIN_ENABLE>;
		eqos_rd1_pe7 {
			nvidia,pins = "eqos_rd1_pe7";
		eqos_rd2_pf0 {
			nvidia,pins = "eqos_rd2_pf0";
		eqos_rd3_pf1 {
			nvidia,pins = "eqos_rd3_pf1";
		eqos_rx_ctl_pf2 {
			nvidia,pins = "eqos_rx_ctl_pf2";
		eqos_rxc_pf3 {
			nvidia,pins = "eqos_rxc_pf3";
		eqos_sma_mdio_pf4 {
			nvidia,pins = "eqos_sma_mdio_pf4";
		eqos_sma_mdc_pf5 {
			nvidia,pins = "eqos_sma_mdc_pf5";
soc_gpio17_pg4 {
nvidia,pins = “soc_gpio17_pg4”;
nvidia,function = “rsvd0”;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
		soc_gpio18_pg5 {
			nvidia,pins = "soc_gpio18_pg5";
			nvidia,function = "rsvd0";
Are you using 10GbE and RGMII at same time? If not, please disable 10GbE from device tree.
Yes, both are in use.And we also expanded a network port with the Intel I210.The 210 is working.
Could you disable all the other 2 and just check RGMII functionality first? For example, not sure if you ever noticed… your RGMII and 10GbE are sharing the same mac addr.
Also, are you sure the pinmux files and dtb really get flashed to your board…
I’m sure.DTB has changed and I checked gpio.
/sys/kernel/debug/gpio
How about the pinmux?
How to confirm pinmux?
Check your flash log if those files are really getting flashed.
dpkg.log (23.7 KB)
is this?
I tested MDIO and MDC.no waveform.
No… how did you flash your jetson orin?
Then read the log printed by flash.sh…
Okay, I’ll flash again and record the print message.
From the log I found that the dtsi file name should contain -a04,Eth1 is now recognized, but it cannot be linked and communicated.
Does the /proc/interrupt |grep eth increase?
