Isaac Sim Version
5.0.0
Operating System
Ubuntu 22.04
GPU Information
- Model: RTX 3090
- Driver Version: 575.64.03
Topic Description
If we create a prim with RigidBodyAPI and set the kinematic attribute to true, then this prim’s rendering pose will not be updated if we use physx set_transforms api to change its pose.
This bug happens when we use cuda backend for the SimulationContext class. No such issue when used with numpy backend. I think this is related to the GPU pipeline of physX and the sync between physX and RTX renderings.
In the video you can see that if I change the kinematic during simulation in the GUI, suddenly the bug disappears.
Detailed Description
import os
import isaacsim
use_full_exp_file = True
simulation_app = isaacsim.SimulationApp(
launch_config={"headless": False},
experience=os.path.join(os.path.dirname(isaacsim.__file__), "apps/isaacsim.exp.full.kit") if use_full_exp_file else None,
import torch
import omni
from pxr import Usd, UsdGeom, Gf, UsdPhysics, Sdf, UsdLux, PhysxSchema
from isaacsim.core.simulation_manager import SimulationManager
from isaacsim.core.api import SimulationContext
from isaacsim.core.api.objects.ground_plane import GroundPlane
from isaacsim.core.utils.viewports import set_camera_view
FRAME_RATE = 60
RENDER_DECIMATION = 1
def create_cube(prim_path: str, kinematic: bool, center: list[float], size: list[float]):
distantLight = UsdLux.DistantLight.Define(stage, Sdf.Path("/Light"))
distantLight.CreateIntensityAttr(3000)
xform = UsdGeom.Cube.Define(stage, prim_path)
xform.CreateSizeAttr().Set(1.0)
xform.AddTranslateOp(UsdGeom.XformOp.PrecisionDouble).Set(Gf.Vec3d(center[0], center[1], center[2]))
xform.AddOrientOp(UsdGeom.XformOp.PrecisionDouble).Set(Gf.Quatd(1.0, 0.0, 0.0, 0.0))
xform.AddScaleOp(UsdGeom.XformOp.PrecisionDouble).Set(Gf.Vec3d(size[0], size[1], size[2]))
collision_api = UsdPhysics.CollisionAPI.Apply(xform.GetPrim())
rigid_body_api = UsdPhysics.RigidBodyAPI.Apply(xform.GetPrim())
if kinematic:
rigid_body_api.CreateKinematicEnabledAttr().Set(True)
def init_physics():
SimulationManager.initialize_physics()
physics_sim_view = SimulationManager.get_physics_sim_view()
physx_view = physics_sim_view.create_rigid_body_view(["/World/Box1", "/World/Box2"])
return physx_view
def main():
sim = SimulationContext(
physics_dt=1 / FRAME_RATE,
rendering_dt=1 / FRAME_RATE,
backend='torch',
device='cuda:0',
GroundPlane(prim_path="/World/GroundPlane", z_position=0, size=10.0)
create_cube(
prim_path="/World/Box1",
kinematic=True,
center=[0, 1, 2],
size=[1, 1, 1],
create_cube(
prim_path="/World/Box2",
kinematic=False,
center=[0, 1, 5],
size=[1, 1, 1],
physx_view = init_physics()
set_camera_view(
eye=[12.0, 0.0, 3],
target=[0.0, 0.0, 2.0],
camera_prim_path="/OmniverseKit_Persp"
sim.reset()
# Define simulation stepping
frame = 0
# Simulate physics
while simulation_app.is_running():
# perform step
sim.step()
frame += 1
if frame % 100 == 0:
print(f"Stepped {frame} frames")
if frame % 300 == 0:
tf = physx_view.get_transforms()
print(f"Transforms at frame {frame}: {tf}")
tf[0, 0] = 0.0
tf[0, 1] = 1.0
tf[0, 2] = 2.0
tf[1, 0] = 0.0
tf[1, 1] = 1.0
tf[1, 2] = 5.0
physx_view.set_transforms(tf, indices=torch.arange(len(tf), device='cuda:0'))
if frame % 300 == 150:
tf[0, 0] = 0.0
tf[0, 1] = -1.0
tf[0, 2] = 2.0
tf[1, 0] = 0.0
tf[1, 1] = -1.0
tf[1, 2] = 5.0
if __name__ == "__main__":
main()
simulation_app.close()
Steps to Reproduce
Run the above code in Isaac Sim 5.0 conda environment.
