Hello.
I’m trying to enable the driver of my graphic card (RTX 2080 ti) inside my Arch Linux virtual machine virtualized with esxi 7 (where I have also set : hypervisor.cpuid.v0 = FALSE). Until now,when I do that,I see this error message between the dmesg messages :
GPU 0000:0b:00.0: RmInitAdapter failed!
The consequence of this error is that the monitor attached to the 2080 ti is not turned on because its driver can’t be initialized and wayland is not shown on the login screen,so it can’t be activated (instead when arch runs physically,wayland is present and can be activated when I use kde plasma). I’ve collected all the relevant informations from the arch linux (physical and virtual) that can help you to investigate the problem, that you can read below :
info gathered by the physical installation of arch-linux :
info gathered by arch linux running with esxi 7
I don’t know what to do further. Please give me some suggestions. thanks.
