Roofline graph Not showing
I created the ncu-rep file via CLI for an open-source Python package that consists of several kernels. The GPU Speed of Light, Section - Floating Point Operation graph is not showing. Please suggest Why it is not showing. Only the GPU Throughput graph is showing.
What CLI flags did you use? The “–set detailed” or “–set full” should contain the info you’re looking for. If you still aren’t seeing the sections you would expect, if possible, attach the result here or send it in a message and I can try and figure out what’s going on.
Thanks @jmarusarz After setting a flag “–set detailed” or “–set full” I am able to see the graph.
