The Roofline chart is not displaying in the NCU-UI after enabling the --set full flag
with ncu option --set full, I get something like this
Then I use --set roofline and I get something like this
Enviroment:
Driver Version: 570.124.04
CUDA Version: 12.8
NVIDIA A100 80GB PCIe
ncu on server: Version 2025.1.1.0
ncu-ui on my Macbook:
Hi @pqjsshamggsh. welcome to the NVIDIA developer forums.
I think this post might get more responses if it is in the NSight section. I hope you don’t mind my moving it for you.
Can you clarify what your question is?
My question is, why I can’t generate a roofline chart using any command line options. But --set full work on another server
Have you tried switching to the roofline chart section body? In your screenshot, the header for the GPU Speed Of Light section has “GPU Throughput Chart” selected. If you collected the roofline(s), you should be able to switch this to other entries, including roofline charts.
I really appreciate your help. This has resolved my issue. Sorry for not checking the settings thoroughly beforehand.
