Why can’t my nsight compute see Floating Point Operations Roofline (Tensor Core)
The machine I use is V100
The version I used for profile is 2023.1.0
What I use for GUI is 2024.3.1
Have you enabled the roofline set to generate the report ?
Can you tell me how to turn on this option please?
I’ve already used the --set full option
I noticed you are using different version of CLI and GUI, can you try to update the CLI version ? 2023.1.0 is relatively old.
https://forums.developer.nvidia.com/uploads/short-url/mQm63wwqMuXuTDqC2aSoLlMtUf2.zip
I tried to use someone else’s file in my GUI and still didn’t see tensor core roofline
The following is mine
mamba2_ge.zip (1.0 MB)
As I said before, please use newer CLI tools to collect the report.
Hi, @1144974269
Good to know you see the roofline now ?
What’s the remained problem now ? Can you clarify ?
Full = full report
Full != All metrics
The roofline sections require a lot of passes. In Metric Selection you can switch from Metric Sets to Metric Sections/Rules to pick individual sections. The “Sets” column will show which sections are in the full or detailed set. In your release the GPU Speed of Light Hierarchical Roofline Charts (* Precision) are only in the roofline set. Through this dialog you can include on the rooflines of interest which will reduce the required metrics.
thanks!so if i want all sections including roofline and others,I just need to use --set full ! ?
The best method is to run the commands
- ncu --list-sets
- ncu --list-sections
In 2024.3.0 full does not include the new roofline sections (SpeedOfLight_HiearchicalTensorRooflineChart).
This would require you to use --section to add sections and likely require you to specify --print-details=all.
ncu --list-sets
Identifier Sections Enabled Estimated Metrics
basic LaunchStats, Occupancy, SpeedOfLight, WorkloadDistribution yes 145
detailed ComputeWorkloadAnalysis, LaunchStats, MemoryWorkloadAnalysis, MemoryWorkloa no 460
dAnalysis_Chart, Occupancy, SourceCounters, SpeedOfLight, SpeedOfLight_Roof
lineChart, WorkloadDistribution
full ComputeWorkloadAnalysis, InstructionStats, LaunchStats, MemoryWorkloadAnaly no 614
sis, MemoryWorkloadAnalysis_Chart, MemoryWorkloadAnalysis_Tables, NumaAffin
ity, Nvlink_Tables, Nvlink_Topology, Occupancy, PmSampling, SchedulerStats,
SourceCounters, SpeedOfLight, SpeedOfLight_RooflineChart, WarpStateStats,
nvlink Nvlink, Nvlink_Tables, Nvlink_Topology no 52
pmsampling PmSampling, PmSampling_WarpStates no 80
roofline SpeedOfLight, SpeedOfLight_HierarchicalDoubleRooflineChart, SpeedOfLight_Hi no 2841
erarchicalHalfRooflineChart, SpeedOfLight_HierarchicalSingleRooflineChart,
SpeedOfLight_HierarchicalTensorRooflineChart, SpeedOfLight_RooflineChart, W
orkloadDistribution
ncu --list-sections
Identifier Display Name Enabled Filename
C2CLink C2CLink no ...sight Compute/2024.3.0/Sections\C2CLink.section
ComputeWorkloadAnalysis Compute Workload Analysis no ...24.3.0/Sections\ComputeWorkloadAnalysis.section
InstructionStats Instruction Statistics no ...2024.3.0/Sections\InstructionStatistics.section
LaunchStats Launch Statistics yes ...pute/2024.3.0/Sections\LaunchStatistics.section
MemoryWorkloadAnalysis Memory Workload Analysis no ...024.3.0/Sections\MemoryWorkloadAnalysis.section
MemoryWorkloadAnalysis_Chart Memory Workload Analysis Chart no ...0/Sections\MemoryWorkloadAnalysis_Chart.section
MemoryWorkloadAnalysis_Tables Memory Workload Analysis Tables no .../Sections\MemoryWorkloadAnalysis_Tables.section
NumaAffinity NUMA Affinity no ... Compute/2024.3.0/Sections\NumaAffinity.section
Nvlink NVLink no ...Nsight Compute/2024.3.0/Sections\Nvlink.section
Nvlink_Tables NVLink Tables no ...Compute/2024.3.0/Sections\Nvlink_Tables.section
Nvlink_Topology NVLink Topology no ...mpute/2024.3.0/Sections\Nvlink_Topology.section
Occupancy Occupancy yes ...ght Compute/2024.3.0/Sections\Occupancy.section
PmSampling PM Sampling no ...ht Compute/2024.3.0/Sections\PmSampling.section
PmSampling_WarpStates PM Sampling: Warp States no ...2024.3.0/Sections\PmSampling_WarpStates.section
SchedulerStats Scheduler Statistics no ...e/2024.3.0/Sections\SchedulerStatistics.section
SourceCounters Source Counters no ...ompute/2024.3.0/Sections\SourceCounters.section
SpeedOfLight GPU Speed Of Light Throughput yes ... Compute/2024.3.0/Sections\SpeedOfLight.section
SpeedOfLight_HierarchicalDoubleRooflineChart GPU Speed Of Light Hierarchical Roofline Chart (Double Precision) no ...OfLight_HierarchicalDoubleRooflineChart.section
SpeedOfLight_HierarchicalHalfRooflineChart GPU Speed Of Light Hierarchical Roofline Chart (Half Precision) no ...edOfLight_HierarchicalHalfRooflineChart.section
SpeedOfLight_HierarchicalSingleRooflineChart GPU Speed Of Light Hierarchical Roofline Chart (Single Precision) no ...OfLight_HierarchicalSingleRooflineChart.section
SpeedOfLight_HierarchicalTensorRooflineChart GPU Speed Of Light Hierarchical Roofline Chart (Tensor Core) no ...OfLight_HierarchicalTensorRooflineChart.section
SpeedOfLight_RooflineChart GPU Speed Of Light Roofline Chart no ...3.0/Sections\SpeedOfLight_RooflineChart.section
WarpStateStats Warp State Statistics no ...e/2024.3.0/Sections\WarpStateStatistics.section
WorkloadDistribution GPU and Memory Workload Distribution yes .../2024.3.0/Sections\WorkloadDistribution.section
