Hello Jerry,
I modified the flash xml file flash_l4t_t186_rootfs_ab.xml to modify for device type sdcard, instance id 1 and num_sectors 268435456 to account for 32Gb sd card size. still I am getting following errors when I try to flash.
sudo ROOTFS_AB=1 tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk1p1 -S 32GiB -c bootloader/t186ref/cfg/flash_l4t_t186_rootfs_ab.xml jetson-xavier-nx-devkit-tx2-nx external
/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device mmcblk1p1 -S 32GiB -c bootloader/t186ref/cfg/flash_l4t_t186_rootfs_ab.xml jetson-xavier-nx-devkit-tx2-nx external
- Step 1: Generate flash packages *
Create folder to store images to flash
Generate images to be flashed
BOOTDEV=external /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/flash.sh --no-flash --sign --external-device -c “bootloader/t186ref/cfg/flash_l4t_t186_rootfs_ab.xml” -S “32GiB” jetson-xavier-nx-devkit-tx2-nx external
L4T BSP Information:
R32 , REVISION: 7.6
./tegraflash.py --chip 0x18 --applet “/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0053 ] Generating RCM messages
[ 0.0064 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0073 ] RCM 0 is saved as rcm_0.rcm
[ 0.0078 ] RCM 1 is saved as rcm_1.rcm
[ 0.0078 ] List of rcm files are saved in rcm_list.xml
[ 0.0078 ]
[ 0.0079 ] Signing RCM messages
[ 0.0103 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0104 ] Assuming zero filled SBK key
[ 0.0172 ] Copying signature to RCM mesages
[ 0.0196 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0317 ]
[ 0.0318 ] Boot Rom communication
[ 0.0342 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0352 ] RCM version 0X180001
[ 0.0624 ] Boot Rom communication completed
[ 1.0693 ]
[ 2.0758 ] tegrarcm_v2 --isapplet
[ 2.0788 ] Applet version 01.00.0000
[ 2.1528 ]
[ 2.1579 ] Retrieving EEPROM data
[ 2.1583 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1609 ] Applet version 01.00.0000
[ 2.2407 ] Saved platform info in /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.3146 ]
Board ID(3636) version(301) sku(0001) revision(G.0)
Copy /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb to /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb.rec
Using UUID 7cad5387-cd29-4c96-9e83-1b00973d8bbc for mounting root APP_ext partition.
Using UUID c07853f8-a1d3-4d6e-91a7-99647f91e6f3 for mounting root APP_b_ext partition.
copying bctfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-memcfg-p3636-0001-a01.cfg)… done.
copying misc_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-p3636-0001-a00.cfg)… done.
copying pmic_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-p3636-0001-a00.cfg)… done.
copying pmc_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-p3636-0001-a00.cfg)… done.
copying prod_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-p3636-0001-a00.cfg)… done.
copying scr_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-p3636-0001-a00.cfg)… done.
copying dev_params(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
done.
/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img kernel
version 1.0.0
[ 0.0004 ] Generating signature
[ 0.0017 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0018 ] Assuming zero filled SBK key : not reading
[ 0.0018 ] sign_type : 0
[ 0.0018 ] header_magic: 414e4452
[ 0.0256 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0290 ]
[ 0.0314 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img zerosbk
[ 0.0338 ]
[ 0.0372 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0373 ] Assuming zero filled SBK key : not reading
[ 0.0535 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0556 ]
[ 0.0565 ] Signed file: /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don’t need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img_b kernel
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0018 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0019 ] Assuming zero filled SBK key : not reading
[ 0.0019 ] sign_type : 0
[ 0.0019 ] header_magic: 414e4452
[ 0.0040 ] tegrahost_v2 --chip 0x18 --align 1_boot.img_b
[ 0.0051 ]
[ 0.0061 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img_b zerosbk
[ 0.0082 ]
[ 0.0114 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_b_list.xml --pubkeyhash pub_key.key
[ 0.0115 ] Assuming zero filled SBK key : not reading
[ 0.0259 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img_b.encrypt 1_boot_sigheader.img_b.hash zerosbk
[ 0.0279 ]
[ 0.0287 ] Signed file: /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img_b.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img_b.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img_b.encrypt
l4t_sign_image.sh: the signed file is /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img_b.encrypt
done.
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.337-tegra
~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra
66034 blocks
Making Recovery image…
copying recdtbfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0.000711384 s, 28.1 kB/s
Existing sosfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing cpu_bootloader(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra186-bpmp-p3636-0001-a00-00.dtb)… done.
Existing scefile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb)… done.
Copying nv_boot_control.conf to rootfs
/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-p3636-0001-p3509-0000-a01.dtb kernel_dtb
version 1.0.0
[ 0.0030 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0031 ] Assuming zero filled SBK key : not reading
[ 0.0031 ] sign_type : 909325875
[ 0.0031 ] header_magic: d00dfeed
[ 0.0052 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-p3636-0001-p3509-0000-a01.dtb
[ 0.0062 ]
[ 0.0085 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_kernel_tegra186-p3636-0001-p3509-0000-a01.dtb zerosbk
[ 0.0098 ]
[ 0.0130 ] tegrasign_v3.py --key --list 1_kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0131 ] Assuming zero filled SBK key : not reading
[ 0.0210 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt 1_kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.hash zerosbk
[ 0.0226 ]
[ 0.0232 ] Signed file: /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra186-p3636-0001-p3509-0000-a01.dtb to rootfs… done.
Making system.img…
populating rootfs from /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Making system.img_b…
Sync’ing system.img_b … done.
system.img_b built successfully.
Existing tbcfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb)… done.
copying cfgfile(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186_rootfs_ab.xml) to flash.xml… done.
Existing flasher(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config tegra186-mb1-bct-memcfg-p3636-0001-a01.cfg --odmdata 0x2090000 --applet mb1_recovery_prod.bin --cmd “sign” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-p3636-0001-a00.cfg --pmic_config tegra186-mb1-bct-pmic-p3636-0001-a00.cfg --pmc_config tegra186-mb1-bct-pad-p3636-0001-a00.cfg --prod_config tegra186-mb1-bct-prod-p3636-0001-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-p3636-0001-a00.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-bpmp-p3636-0001-a00-00.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-p3636-0001-p3509-0000-a01.dtb” --external_device
saving flash command in /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate flashing ready partition images… ***
version 1.0.0
[ 0.0207 ] Using default ramcode: 0
[ 0.0207 ] Disable BPMP dtb trim, using default dtb
[ 0.0207 ]
[ 0.0337 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0338 ] Assuming zero filled SBK key
[ 0.0335 ] Generating RCM messages
[ 0.0366 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0377 ] RCM 0 is saved as rcm_0.rcm
[ 0.0608 ] RCM 1 is saved as rcm_1.rcm
[ 0.0608 ] List of rcm files are saved in rcm_list.xml
[ 0.0608 ]
[ 0.0608 ] Signing RCM messages
[ 0.0644 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0646 ] Assuming zero filled SBK key
[ 0.0814 ] Copying signature to RCM mesages
[ 0.0843 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0864 ]
[ 0.0865 ] Parsing partition layout
[ 0.0973 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0987 ] Invalid device type sdcard_user
[ 0.1014 ]
Error: Return value 4
Command tegraparser_v2 --pt flash.xml.tmp
Error: /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /home/anand/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up…
