Rootfs does not support NFS export
Hi all,
I am trying to flash an Orin NX on a Xavier NX devkit. This is working fine through the SDK manager, but I want to do this through the cli. I am following these steps: Quick Start — Jetson Linux Developer Guide documentation
However I get the message that the rootfs does not support NFS export. How can I solve this?
I am using Ubuntu 18.04
What is the error message? There are usually requirements for both user space tools to be installed, and certain kernel drivers being enabled. It is unlikely that a rootfs does not support export, although I will say it is (for security reasons) usually a "very bad idea"™ to export the full rootfs.
PS: I wish I could patent “very bad ideas” :P
There is no error message. Its just this:
If I execute the steps on my native ubuntu 20.04 it works fine. But I would like to run it in a docker container. Then it does this.
There are some filesystem types NFS might not be able to export. What do you see from:
df -H -T /home/ubuntu/Linux_for_Tegra/rootfs
This will show disk space, and also the type of filesystem. Is there anything unusual about this, e.g., it isn’t on ext4?
