Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
X Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
X other
Host Machine Version
other
Hi, I am trying to run a sample program deviceQuery from the /opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery directory inside a rootless podman container.
I believe this program is using CUDA libraries to interact with the GPU.
When I ran this program directly on the host, it worked.
However, when I ran this inside a rootless podman container, i got the error “cudaGetDeviceCount not supported”
root@tegra-ubuntu:/opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery# ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 801
-> operation not supported
Result = FAIL
root@tegra-ubuntu:/opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery# exit
exit
nvidia@tegra-ubuntu:/opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery$ ./deviceQuery
Detected 1 CUDA Capable device(s)
Device 0: "Orin"
CUDA Driver Version / Runtime Version 12.1 / 11.4
CUDA Capability Major/Minor version number: 8.7
Total amount of global memory: 28954 MBytes (30360899584 bytes)
(016) Multiprocessors, (128) CUDA Cores/MP: 2048 CUDA Cores
GPU Max Clock rate: 1275 MHz (1.27 GHz)
Memory Clock rate: 1275 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 167936 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 12.1, CUDA Runtime Version = 11.4, NumDevs = 1
Result = PASS
I followed Installing the NVIDIA Container Toolkit — NVIDIA Container Toolkit 1.16.0 documentation and Support for Container Device Interface — NVIDIA Container Toolkit 1.16.0 documentation to set up Podman.
I am pretty sure this is not a driver and CUDA versoin compatibility issue.
Can someone shed some light on this? i have been stuck on this a many days
pnvidia@tegra-ubuntu:/opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery$ podman info
host:
arch: arm64
buildahVersion: 1.33.2
cgroupControllers:
- memory
- pids
cgroupManager: cgroupfs
cgroupVersion: v2
conmon:
package: Unknown
path: /usr/local/libexec/podman/conmon
version: 'conmon version 2.1.12, commit: 3bc422cd8aaec542d85d1a80f2d38e6e69046b5b'
cpuUtilization:
idlePercent: 99.86
systemPercent: 0.08
userPercent: 0.07
cpus: 12
databaseBackend: sqlite
distribution:
codename: focal
distribution: ubuntu
version: "20.04"
eventLogger: file
freeLocks: 2047
hostname: tegra-ubuntu
idMappings:
gidmap:
- container_id: 0
host_id: 1000
- container_id: 1
host_id: 100000
uidmap:
- container_id: 0
host_id: 1000
- container_id: 1
host_id: 100000
kernel: 5.15.122-rt-tegra
linkmode: dynamic
logDriver: k8s-file
memFree: 25436360704
memTotal: 30360899584
networkBackend: cni
networkBackendInfo:
backend: cni
dns: {}
package: containernetworking-plugins_0.8.5-1_arm64
path: /usr/lib/cni
ociRuntime:
package: crun_0.12.1+dfsg-1_arm64
path: /usr/bin/crun
version: |-
crun version 0.12.1
commit: df5f2b2369b3d9f36d175e1183b26e5cee55dd0a
spec: 1.0.0
+SYSTEMD +SELINUX +APPARMOR +CAP +SECCOMP +EBPF +YAJL
os: linux
pasta:
executable: ""
package: ""
version: ""
remoteSocket:
exists: false
path: /run/user/1000/podman/podman.sock
security:
apparmorEnabled: false
capabilities: CAP_CHOWN,CAP_DAC_OVERRIDE,CAP_FOWNER,CAP_FSETID,CAP_KILL,CAP_NET_BIND_SERVICE,CAP_SETFCAP,CAP_SETGID,CAP_SETPCAP,CAP_SETUID,CAP_SYS_CHROOT
rootless: true
seccompEnabled: true
seccompProfilePath: ""
selinuxEnabled: false
serviceIsRemote: false
slirp4netns:
executable: /usr/bin/slirp4netns
package: slirp4netns_0.4.3-1_arm64
version: |-
slirp4netns version 0.4.3
commit: 2244b9b6461afeccad1678fac3d6e478c28b4ad6
swapFree: 0
swapTotal: 0
uptime: 7h 56m 59.00s (Approximately 0.29 days)
variant: v8
plugins:
authorization: null
log:
- k8s-file
- none
- passthrough
network:
- bridge
- macvlan
- ipvlan
volume:
- local
registries:
search:
- docker.io
- quay.io
store:
configFile: /home/nvidia/.config/containers/storage.conf
containerStore:
number: 1
paused: 0
running: 1
stopped: 0
graphDriverName: overlay
graphOptions: {}
graphRoot: /home/nvidia/.local/share/containers/storage
graphRootAllocated: 27292614656
graphRootUsed: 10870382592
graphStatus:
Backing Filesystem: extfs
Native Overlay Diff: "true"
Supports d_type: "true"
Supports shifting: "false"
Supports volatile: "true"
Using metacopy: "false"
imageCopyTmpDir: /var/tmp
imageStore:
number: 5
runRoot: /run/user/1000/containers
transientStore: false
volumePath: /home/nvidia/.local/share/containers/storage/volumes
version:
APIVersion: 4.8.3
Built: 1723775305
BuiltTime: Fri Aug 16 02:28:25 2024
GitCommit: 85dc30df56566a654700722a4dd190e1b9680ee7
GoVersion: go1.22.6
Os: linux
OsArch: linux/arm64
Version: 4.8.3
NVRM version: NVIDIA UNIX Open Kernel Module for aarch64 541.2.0 Release Build (root@xinronch-ubuntu) Wed Aug 14 18:24:07 UTC 2024
GCC version: gcc version 9.3.0 (Buildroot 2020.08)
"cuda" : {
"name" : "CUDA SDK",
"version" : "11.4.30"
"cuda_cudart" : {
"name" : "CUDA Runtime (cudart)",
"version" : "11.4.532"
"cuda_cuobjdump" : {
"name" : "cuobjdump",
"cuda_cupti" : {
"name" : "CUPTI",
"cuda_cuxxfilt" : {
"name" : "CUDA cu++ filt",
"cuda_gdb" : {
"name" : "CUDA GDB",
"cuda_nvcc" : {
"name" : "CUDA NVCC",
"cuda_nvdisasm" : {
"name" : "CUDA nvdisasm",
"cuda_nvprune" : {
"name" : "CUDA nvprune",
"cuda_nvrtc" : {
"name" : "CUDA NVRTC",
"cuda_nvtx" : {
"name" : "CUDA NVTX",
"cuda_samples" : {
"name" : "CUDA Samples",
"cuda_sanitizer_api" : {
"name" : "CUDA Compute Sanitizer API",
"cuda_thrust" : {
"name" : "CUDA C++ Core Compute Libraries",
"libcublas" : {
"name" : "CUDA cuBLAS",
"version" : "11.6.6.316"
"libcudla" : {
"name" : "CUDA cuDLA",
"libcufft" : {
"name" : "CUDA cuFFT",
"version" : "10.6.0.436"
"libcurand" : {
"name" : "CUDA cuRAND",
"version" : "10.2.5.531"
"libcusolver" : {
"name" : "CUDA cuSOLVER",
"version" : "11.2.0.531"
"libcusparse" : {
"name" : "CUDA cuSPARSE",
"version" : "11.6.0.531"
"libnpp" : {
"name" : "CUDA NPP",
"version" : "11.4.0.521"
"nsight_compute" : {
"name" : "Nsight Compute",
"version" : "2021.2.10.1"
permissions of device files that container sees
root@tegra-ubuntu:/opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery# ls -ld /dev/n*
ls: /usr/lib/aarch64-linux-gnu/libselinux.so.1: no version information available (required by ls)
crw-rw-rw- 1 root root 1, 3 Aug 17 00:44 /dev/null
drwxr-xr-x 3 root root 60 Aug 17 00:44 /dev/nvgpu
crw-rw-rw- 1 root root 472, 0 Aug 17 00:44 /dev/nvhost-as-gpu
crw-rw-rw- 1 root root 472, 2 Aug 17 00:44 /dev/nvhost-ctrl-gpu
crw-rw-rw- 1 root root 486, 0 Aug 17 00:44 /dev/nvhost-ctrl-isp
crw-rw-rw- 1 root root 498, 0 Aug 17 00:44 /dev/nvhost-ctrl-isp-thi
crw-rw-rw- 1 root root 490, 0 Aug 17 00:44 /dev/nvhost-ctrl-nvcsi
crw-rw-rw- 1 root root 495, 0 Aug 17 00:44 /dev/nvhost-ctrl-nvdla0
crw-rw-rw- 1 root root 493, 0 Aug 17 00:44 /dev/nvhost-ctrl-nvdla1
crw-rw-rw- 1 root root 492, 0 Aug 17 00:44 /dev/nvhost-ctrl-pva0
crw-rw-rw- 1 root root 489, 0 Aug 17 00:44 /dev/nvhost-ctrl-vi0
crw-rw-rw- 1 root root 501, 0 Aug 17 00:44 /dev/nvhost-ctrl-vi0-thi
crw-rw-rw- 1 root root 488, 0 Aug 17 00:44 /dev/nvhost-ctrl-vi1
crw-rw-rw- 1 root root 500, 0 Aug 17 00:44 /dev/nvhost-ctrl-vi1-thi
crw-rw-rw- 1 root root 472, 3 Aug 17 00:44 /dev/nvhost-ctxsw-gpu
crw-rw-rw- 1 root root 472, 4 Aug 17 00:44 /dev/nvhost-dbg-gpu
crw-rw-rw- 1 root root 472, 1 Aug 17 00:44 /dev/nvhost-gpu
crw-rw-rw- 1 root root 472, 9 Aug 17 00:44 /dev/nvhost-nvsched-gpu
crw-rw-rw- 1 root root 472, 10 Aug 17 00:44 /dev/nvhost-nvsched_ctrl_fifo-gpu
crw-rw-rw- 1 root root 502, 0 Aug 17 00:44 /dev/nvhost-power-gpu
crw-rw-rw- 1 root root 472, 6 Aug 17 00:44 /dev/nvhost-prof-ctx-gpu
crw-rw-rw- 1 root root 472, 7 Aug 17 00:44 /dev/nvhost-prof-dev-gpu
crw-rw-rw- 1 root root 472, 5 Aug 17 00:44 /dev/nvhost-prof-gpu
crw-rw-rw- 1 root root 472, 8 Aug 17 00:44 /dev/nvhost-sched-gpu
crw-rw-rw- 1 root root 472, 11 Aug 17 00:44 /dev/nvhost-tsg-gpu
crwxrwxrwx 1 root root 195, 254 Aug 17 00:44 /dev/nvidia-modeset
crwxrwxrwx 1 root root 195, 0 Aug 17 00:44 /dev/nvidia0
crwxrwxrwx 1 root root 195, 255 Aug 17 00:44 /dev/nvidiactl
crw-rw-rw- 1 root root 10, 79 Aug 17 00:44 /dev/nvmap
Tried running using sudo and --privileged, the issue persists
config.toml
#accept-nvidia-visible-devices-as-volume-mounts = false
#accept-nvidia-visible-devices-envvar-when-unprivileged = true
disable-require = false
supported-driver-capabilities = "compat32,compute,display,graphics,ngx,utility,video"
#swarm-resource = "DOCKER_RESOURCE_GPU"
[nvidia-container-cli]
#debug = "/var/log/nvidia-container-toolkit.log"
environment = []
#ldcache = "/etc/ld.so.cache"
ldconfig = "@/sbin/ldconfig.real"
load-kmods = true
no-cgroups = true
#path = "/usr/bin/nvidia-container-cli"
#root = "/run/nvidia/driver"
#user = "root:video"
[nvidia-container-runtime]
#debug = "/var/log/nvidia-container-runtime.log"
log-level = "info"
mode = "auto"
runtimes = ["docker-runc", "runc", "crun"]
[nvidia-container-runtime.modes]
[nvidia-container-runtime.modes.cdi]
annotation-prefixes = ["cdi.k8s.io/"]
default-kind = "nvidia.com/gpu"
spec-dirs = ["/etc/cdi", "/var/run/cdi"]
[nvidia-container-runtime.modes.csv]
mount-spec-path = "/etc/nvidia-container-runtime/host-files-for-container.d"
[nvidia-container-runtime-hook]
path = "nvidia-container-runtime-hook"
skip-mode-detection = false
[nvidia-ctk]
path = "nvidia-ctk"
devices.csv
dev, /dev/nvhost-tsg-gpu
dev, /dev/nvhost-nvsched_ctrl_fifo-gpu
dev, /dev/nvhost-nvsched-gpu
dev, /dev/nvhost-sched-gpu
dev, /dev/nvhost-prof-dev-gpu
dev, /dev/nvhost-prof-ctx-gpu
dev, /dev/nvhost-prof-gpu
dev, /dev/nvhost-dbg-gpu
dev, /dev/nvhost-ctxsw-gpu
dev, /dev/nvhost-ctrl-gpu
dev, /dev/nvhost-gpu
dev, /dev/nvhost-as-gpu
dev, /dev/nvhost-ctrl-isp
dev, /dev/nvhost-ctrl-vi1
dev, /dev/nvhost-ctrl-nvcsi
dev, /dev/nvhost-ctrl-vi0
dev, /dev/nvhost-ctrl-pva0
dev, /dev/nvhost-ctrl-nvdla1
dev, /dev/nvhost-ctrl-nvdla0
dev, /dev/nvhost-ctrl-isp-thi
dev, /dev/nvhost-ctrl-vi1-thi
dev, /dev/nvhost-ctrl-vi0-thi
dev, /dev/nvhost-power-gpu
dev, /dev/nvgpu/igpu0/tsg
dev, /dev/nvgpu/igpu0/nvsched_ctrl_fifo
dev, /dev/nvgpu/igpu0/sched
dev, /dev/nvgpu/igpu0/prof-dev
dev, /dev/nvgpu/igpu0/prof-ctx
dev, /dev/nvgpu/igpu0/dbg
dev, /dev/nvgpu/igpu0/ctxsw
dev, /dev/nvgpu/igpu0/ctrl
dev, /dev/nvgpu/igpu0/channel
dev, /dev/nvgpu/igpu0/as
dev, /dev/nvgpu/igpu0/power
dev, /dev/nvmap
dev, /dev/nvidia0
dev, /dev/nvidiactl
dev, /dev/nvidia-modeset
nvidia@tegra-ubuntu:/opt/nvidia/drive-linux/NVIDIA_CUDA-11.4_Samples/bin/aarch64/linux/release$ sudo podman run --rm -v $(pwd):$(pwd) -w $(pwd) --device /dev/nvidia0 --device /dev/nvidiactl --device /dev/nvidia-modeset --device nvidia.com/gpu=0 --runtime=runc --gpus all -e NVIDIA_VISIBLE_DEVICES=1 -e CUDA_VISIBLE_DEVICES=1 --security-opt label=disable --security-opt apparmor=unconfined --read-only=false --security-opt seccomp=unconfined -it --network=host ubuntu:20.04 ./deviceQuery
Result = FAIL
i wrote a simple CPP program to call cudaGetDeviceCount, and it also failed with ERROR_OPERATIO_NOT_SUPPORTED when running insode a podman container
#include <cuda_runtime.h>
#include <iostream>
int main() {
int device_count = 0;
cudaError_t error = cudaGetDeviceCount(&device_count);
if (error != cudaSuccess) {
std::cerr << "CUDA error: " << cudaGetErrorString(error) << std::endl;
return 1;
std::cout << "Number of CUDA devices: " << device_count << std::endl;
for (int i = 0; i < device_count; ++i) {
cudaDeviceProp device_prop;
cudaGetDeviceProperties(&device_prop, i);
std::cout << "Device " << i << ": " << device_prop.name << std::endl;
return 0;
