Hello Everyone…
Recently I started learning ROS and I was able to do a differential drive robot build with 2D Mapping with Gmapping and 3D mapping with RTAB-Map with Microsoft Kinect v1. So I’m here to share my experience with you… I posted a video on youtube of the build i did. I named it NavBot.
So i was able perform SLAM with Gmapping and i had to build gmapping from the source as it is not updated for ROS melodic. I added gmapping source package files into my project git so it will be easy to use. I used Differential drive controller from ROS Control to get odometry.
Here is the Link to project GitHub repository - GitHub - imeshsps/ros-navbot: Indoor Mapping and Navigation Robot Build with ROS and Nvidia Jetson Nano
If i visualize 3D point Clouds in Nano, It seems to get stuck so i did visualizations in my laptop connected to ROS master running on the Nano. Other than that everything worked fine.
So if you are doing a similar build, I think this will help and if you having problems related to this, Please comment it here i’m really happy to help.
Really cool project, thanks for sharing!
Good project, could you help me I’m trying to connect Microsoft Kinect v1 with Ros in the nano jetson but I have not been successful, I need to use skeleton trakin
Thank you…
Thanks… To use kinect with ros I used openni_launch
ROS package which is available for Melodic and also freenect_launch also worked. But it is only there for kinetic. Did you tried with openni_launch ? I added the links below…
http://wiki.ros.org/openni_launch
http://wiki.ros.org/freenect_launch
Hi, I really appreciate your work and the amount of work you put into it. I was thinking about making a similar project at my college but i don’t have much experience in jetson nano. is there any way i could contact you if your are willing to help me out ?. I really wanted to try this myself. Thank you !
Hey… ask anything you need here, i’ll help as much as possible…
Im kinda new to this so im afraid i may ask basic stuffs and things may get loong here but anyway here i go:
I really don’t know where to start. i just have my jetson running, i have my kinect v1 with me and pretty much all components you used.
I wanna know if i need to configure the jetson specifically for this project , dependencies to install. Im currently running jetson in headed mode.
I went through your github code. But im not sure how to get it running
I really appreciate if you could provide a step by step instruction ( any help form you means a lot to me actually) to make this myself
Nice job, thank you for sharing
