ROS2 bridge does not work with Cyclone DDS
Isaac Sim Version
5.1.0
Operating System
Ubuntu 24.04, on aws server
GPU Information
  • Model: NVIDIA L40S (aws)
  • Driver Version: 570.172.08
Topic Description
Detailed Description
We use ROS2 jazzy with Cyclone DDS in our SW stack. When I follow the instructions to use Cyclone DDS (cyclone dds instructions) and start isaac sim, no ROS2 actions graphs are available when starting isaac via isaac-sim.sh.
Steps to Reproduce
  • remove "isaacsim.ros2.bridge" in ~/isaacsim/apps/isaacsim.exp.full.kit
  • I export relevant env:
export ROS_DOMAIN_ID=41
export CYCLONEDDS_URI=“~/cyclondds_config.xml”
export ROS_DISTRO=jazzy
export RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/IsaacSim/exts/isaacsim.ros2.bridge/jazzy/lib
  • I start isaac via bash isaac-sim.sh the ros bridge is not loaded (e.g. there are no ros2 nodes in the Action Graph explorer)
  • When I start isaac without setting the cyclone dds env, ROS2 gets correctly loaded and I get the following output
[29.268s] [ext: isaacsim.exp.full-5.1.0] startup
[29.558s] [ext: isaacsim.ros2.bridge-4.12.4] startup
[29.976s] Attempting to load system rclpy
[29.976s] Could not import system rclpy: No module named ‘rclpy’
[29.976s] Attempting to load internal rclpy for ROS Distro: jazzy
[30.060s] rclpy loaded
Error Messages
None
Screenshots or Videos
Can be provided if needed
Additional Information
What I’ve Tried
In contrast with isaac-sim.selector.sh ROS2 action graphs are loaded (still there seem to be some problems that outside ROS2 nodes cannot pick up the topics)
According to the documentation, the ROS_DISTRO env variable is used to check for ROS2 sourcing.
The ROS_DISTRO env variable is used to determine if ROS 2 is sourced and which distro to use. If this variable is not set, an internal ROS 2 distro build is used. Message definitions can be different between ROS 2 versions. Because of this, the appropriate ROS 2 backend is dynamically loaded depending on the sourced ROS distro.
Hence, i don’t think you should manually export it if you want to make Isaac Sim load its internal ROS libraries.
(I am using ros_bridge with CycloneDDS without any issues)
Also without setting the ROS_DISTRO env Isaac does not start ROS2. Somehow it is missing the argument/flag to start the bridge. Can you share your exact steps to start isaac?
did you also remove the LD_LIBRARY path?
on my setup i only exported the Cyclone RMW_IMPLEMENTATION and the ROS_DOMAIN_ID and i confirm it is working fine
Ok, the missing step for me was:
Window → Extensions → Search for ROS 2 BRIDGE → enable + Autoload
or
bash isaac-sim.sh --enable isaacsim.ros2.bridge
or
add in apps/isaacsim.exp.full.kit under
[dependencies]
"isaacsim.ros2.bridge" = {}
Thanks @JeanLesur for giving me confidence that cyclonedds is working for you, so I kept investigating :-)
