I’m looking for information/guidance to read data from a rotary encoder with the Jetson Nano. The encoder I’m using is the is the LPD3806-360BM; see below. I can successfully read the signals from the encoder using a Raspberry Pi but wanted to try the Nano. In researching the forums I came across a post outlining the use of a modified python module Gaugette; available from Github. However reading that post I wasn’t sure the result was successful.
If additional hardware is required, suggestions would be greatly appreciated.
Thank you
Brian Mc.
