Jetson Nano + Arduino due
Hello, i am trying to build a mobile 4 wheeled rover with 4 quadrature encoders
i use an arduino due to read the encoder counts and then later publish them as ros topics.
I know that my arduino code is correct since i have got it working with my pc running ros kinetic,
however jetson nano uses ros melodic but the python scripts working as drivers should’t be affected
When i connect the arduino due to the Nano through usb, it returns wrong encoder count values back to the Nano although the communication bewteen them is succesfull.
I’m a little lost, what advice you give me to connect arduino boards with the nano specifically (due with ros), should i use I2C instead of the usb?
Are there any easy ways to read 4 quadrature encoders directly to the nano and sent pwm pulses?
Thank you, sorry for the ambiquity of my question
You may check other users’ experience:
https://devtalk.nvidia.com/search/more/sitecommentsearch/arduino/
You might want to have a look at what this individual did.
https://github.com/EwingKang/Simple-ROS-Arduino-odometry
Why must we use the arduino, Teensy… to read quadrature encoders?
I have configured Jetson nano GPIO to read pulses of quadrature encoders, and I have use interrupts and it has a big problem to attended the request and it never count well the pulses, nither higth speed nither low speed.
Hi i have fixed that problem, i think the easiest way is with rosserial + an arduino due so it will have the compute to read the 4 encoders directly + pid + publish encoder ticks for odometry, #defive USE_USBCON in order for rosserial to work with arduino due, check this GitHub - panagelak/4WD-drive-arduino-code-with-rosserial-encoders-pid: arduino due code to control a 4 wheeled differential vehicle by a cmd_vel callback using rosserial pid_arduino_library and quadrature_encoder library
or my project GitHub - panagelak/Open_Mobile_Manipulator: A cheap educational DIY mobile manipulator - ROS , with instructions on how to build it, starting code and demos
