My Xavier target installed with the latest Jetpack (4.2) and the version of linux kernel is 4.9.140
I want to patch this kernel with rt-patch.
Which rt-patch version nvidia use to patch this kernel?
After I followed all the instructions and execute the command:
root@yair-OptiPlex-7040:/home/yair/Downloads/XavierBSP/Kernel_Sources/kernel/kernel-4.9# ./scripts/rt-patch.sh apply-patches with success, I tried to rebuild the kernel and got the following error:
root@yair-OptiPlex-7040:/home/yair/Downloads/XavierBSP/Kernel_Sources/kernel/kernel-4.9# make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
make[1]: Entering directory ‘/home/yair/Downloads/XavierBSP/TegraKernelOut1’
GEN ./Makefile
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
GEN ./Makefile
WRAP arch/arm64/include/generated/asm/bugs.h
WRAP arch/arm64/include/generated/asm/clkdev.h
WRAP arch/arm64/include/generated/asm/cputime.h
WRAP arch/arm64/include/generated/asm/delay.h
WRAP arch/arm64/include/generated/asm/div64.h
WRAP arch/arm64/include/generated/asm/dma.h
WRAP arch/arm64/include/generated/asm/dma-contiguous.h
WRAP arch/arm64/include/generated/asm/early_ioremap.h
WRAP arch/arm64/include/generated/asm/emergency-restart.h
WRAP arch/arm64/include/generated/asm/errno.h
WRAP arch/arm64/include/generated/asm/hw_irq.h
WRAP arch/arm64/include/generated/asm/ioctl.h
CHK include/generated/uapi/linux/version.h
WRAP arch/arm64/include/generated/asm/ioctls.h
UPD include/generated/uapi/linux/version.h
WRAP arch/arm64/include/generated/asm/ipcbuf.h
WRAP arch/arm64/include/generated/asm/irq_regs.h
UPD include/config/kernel.release
WRAP arch/arm64/include/generated/asm/kdebug.h
WRAP arch/arm64/include/generated/asm/kmap_types.h
WRAP arch/arm64/include/generated/asm/kvm_para.h
WRAP arch/arm64/include/generated/asm/local.h
WRAP arch/arm64/include/generated/asm/local64.h
WRAP arch/arm64/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm64/include/generated/asm/mman.h
WRAP arch/arm64/include/generated/asm/mcs_spinlock.h
WRAP arch/arm64/include/generated/asm/msgbuf.h
WRAP arch/arm64/include/generated/asm/msi.h
WRAP arch/arm64/include/generated/asm/mutex.h
WRAP arch/arm64/include/generated/asm/poll.h
WRAP arch/arm64/include/generated/asm/resource.h
WRAP arch/arm64/include/generated/asm/preempt.h
WRAP arch/arm64/include/generated/asm/rwsem.h
WRAP arch/arm64/include/generated/asm/segment.h
WRAP arch/arm64/include/generated/asm/sembuf.h
WRAP arch/arm64/include/generated/asm/serial.h
WRAP arch/arm64/include/generated/asm/shmbuf.h
WRAP arch/arm64/include/generated/asm/sizes.h
WRAP arch/arm64/include/generated/asm/simd.h
WRAP arch/arm64/include/generated/asm/socket.h
HOSTCC scripts/basic/bin2c
WRAP arch/arm64/include/generated/asm/sockios.h
WRAP arch/arm64/include/generated/asm/swab.h
WRAP arch/arm64/include/generated/asm/switch_to.h
WRAP arch/arm64/include/generated/asm/termbits.h
WRAP arch/arm64/include/generated/asm/termios.h
WRAP arch/arm64/include/generated/asm/trace_clock.h
WRAP arch/arm64/include/generated/asm/types.h
WRAP arch/arm64/include/generated/asm/unaligned.h
WRAP arch/arm64/include/generated/asm/user.h
WRAP arch/arm64/include/generated/asm/vga.h
WRAP arch/arm64/include/generated/asm/xor.h
WRAP arch/arm64/include/generated/uapi/asm/kvm_para.h
Using /home/yair/Downloads/XavierBSP/Kernel_Sources/kernel/kernel-4.9 as source for kernel
CHK include/generated/utsrelease.h
“4.9.140-rt93— localversion-rt +++ localversion-rt @@ -1 +1 @@ --rt23 ±rt93” exceeds 64 characters
/home/yair/Downloads/XavierBSP/Kernel_Sources/kernel/kernel-4.9/Makefile:1242: recipe for target ‘include/generated/utsrelease.h’ failed
make[1]: *** [include/generated/utsrelease.h] Error 1
make[1]: *** Waiting for unfinished jobs…
make[1]: Leaving directory ‘/home/yair/Downloads/XavierBSP/TegraKernelOut1’
Makefile:171: recipe for target ‘sub-make’ failed
make: *** [sub-make] Error 2
Please advice,
