Hello All,
I am trying to patches the latest L4T 32.1 with Preempt RT. The script I used was rt-patch.sh under folder “/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9/scripts”. However after running the script, the results come as following.
racecar@nvidia:/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9/scripts$ ./rt-patch.sh apply-patches
find: ‘…/rt-patches’: No such file or directory
cp: cannot stat ‘…/arch/arm64/configs/tegra_gnu_linux_defconfig’: No such file or directory
grep: …/arch/arm64/configs/tegra_gnu_linux_defconfig: No such file or directory
./config: line 112: …/arch/arm64/configs/tegra_gnu_linux_defconfig: No such file or directory
Here is “uname -a” after running the script.
racecar@nvidia:/usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9/scripts$ uname -a
Linux nvidia 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
I was doing this directly on the Jetson TX2. I would like to know what would be the correct procedure for applying a preempt rt patch to the L4T 32.1.
Thank you very much.
