In AGX Xavier, what is the current consumption on VCC_RTC pin when system is disconnected from power ?
Thanks,
Rohini
Thanks,
Rohini
It’s about 2uA.
Hi Trumany,
Thanks for the reply
-Rohini
Hi Trumany,
Below information I got from AGX module datasheet. Is it a battery (which we have planned to use) voltage requirement or battery charging voltage requirement
“Note
A voltage range of 2.5V to 3.5V is supported on both JAX and JAXi modules, but may not be compatible with future
modules. To be compatible with future modules of the same connector, 3.3V should be used.”
Awaiting for your response
Thanks,
Rohini
It is battery voltage requirement.
