RTSP of camera not working on deep stream
• Hardware Platform (Jetson / GPU) Jetson AGX
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.5
• TensorRT Version 7.1.3
While i was taking RTSP feed from camera i am getting this error:
gst-stream-error-quark: No decoder available for type ‘application/x-rtp, media=(string)application, payload=(int)107, clock-rate=(int)90000, encoding-name=(string)VND.ONVIF.METADATA, a-charset=(string)Shift_JIS, a-etag=(string)1234567890, x-onvif-track=(string)“trackID=1”, a-recvonly=(string)“”, ssrc=(uint)688438441, clock-base=(uint)0, seqnum-base=(uint)0, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1’. (6): gsturidecodebin.c(921): unknown_type_cb (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin
gstreamer rtspsrc follows RFC 2326, rtspsrc (gstreamer.freedesktop.org), please consult your camera vendor of the compatibility.
