RTSP video stream
Hardware Platform: Jetson nano
DeepStream Version: 6.0
JetPack Version: 4.6.1
I am getting this error when I try to stream the RTSP video on vlc:
g_object_get_is_valid_property: object class ‘GstUDPSrc’ has no property named ‘pt’
My sink in the config file:
[sink0]
enable=1
type=4
codec=1
enc-type=0
sync=0
bitrate=15000
profile=0
rtsp-port=8554
udp-port=5400
source-id=0
udpsrc does not support setting pt attributes.
You can obtain the settable attributes of udpsrc through gst-inspect-1.0 udpsrc.
I got this result:
Factory Details:
  Rank                     none (0)
  Long-name                UDP packet receiver
  Klass                    Source/Network
  Description              Receive data over the network via UDP
  Author                   Wim Taymans <wim@fluendo.com>, Thijs Vermeir <thijs.vermeir@barco.com>
Plugin Details:
  Name                     udp
  Description              transfer data via UDP
  Filename                 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstudp.so
  Version                  1.14.5
  License                  LGPL
  Source module            gst-plugins-good
  Source release date      2019-05-29
  Binary package           GStreamer Good Plugins (Ubuntu)
  Origin URL               https://launchpad.net/distros/ubuntu/+source/gst-plugins-good1.0
GObject
 +----GInitiallyUnowned
       +----GstObject
             +----GstElement
                   +----GstBaseSrc
                         +----GstPushSrc
                               +----GstUDPSrc
Implemented Interfaces:
  GstURIHandler
Pad Templates:
  SRC template: 'src'
    Availability: Always
    Capabilities:
      ANY
Element has no clocking capabilities.
URI handling capabilities:
  Element can act as source.
  Supported URI protocols:
    udp
Pads:
  SRC: 'src'
    Pad Template: 'src'
Element Properties:
  name                : The name of the object
                        flags: readable, writable
                        String. Default: "udpsrc0"
  parent              : The parent of the object
                        Object of type "GstObject"
  blocksize           : Size in bytes to read per buffer (-1 = default)
                        Unsigned Integer. Range: 0 - 4294967295 Default: 4096
  num-buffers         : Number of buffers to output before sending EOS (-1 = unlimited)
                        Integer. Range: -1 - 2147483647 Default: -1
  typefind            : Run typefind before negotiating (deprecated, non-functional)
                        flags: readable, writable, deprecated
                        Boolean. Default: false
  do-timestamp        : Apply current stream time to buffers
                        Boolean. Default: true
  port                : The port to receive the packets from, 0=allocate
                        Integer. Range: 0 - 65535 Default: 5004
  multicast-group     : The Address of multicast group to join. (DEPRECATED: Use address property instead)
                        String. Default: "0.0.0.0"
  multicast-iface     : The network interface on which to join the multicast group.This allows multiple interfaces seperated by comma. ("eth0,eth1")
                        String. Default: null
  uri                 : URI in the form of udp://multicast_group:port
                        String. Default: "udp://0.0.0.0:5004"
  caps                : The caps of the source pad
                        Caps (NULL)
  socket              : Socket to use for UDP reception. (NULL == allocate)
                        Object of type "GSocket"
  buffer-size         : Size of the kernel receive buffer in bytes, 0=default
                        Integer. Range: 0 - 2147483647 Default: 0
  timeout             : Post a message after timeout nanoseconds (0 = disabled)
                        Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
  skip-first-bytes    : number of bytes to skip for each udp packet
  close-socket        : Close socket if passed as property on state change
  used-socket         : Socket currently in use for UDP reception. (NULL = no socket)
                        flags: readable
  auto-multicast      : Automatically join/leave multicast groups
  reuse               : Enable reuse of the port
  address             : Address to receive packets for. This is equivalent to the multicast-group property for now
  loop                : Used for setting the multicast loop parameter. TRUE = enable, FALSE = disable
  retrieve-sender-address: Whether to retrieve the sender address and add it to buffers as meta. Disabling this might result in minor performance improvements in certain scenarios
Sounds everything is fine. I also checked the permissions and the firewalls and everything is good.
[/quote]
Sounds like the warning above is harmless, as it worked fine with it.
I only rebooted the Jetson and it worked fine.
This error usually does not affect the normal running of the program.
Which sample did you use? Have you modified the code? Have you added code like g_object_set (G_OBJECT (udpsrc), "pt", 1, NULL); ?
It is usually the above statement that causes this error.
