I have ASRock A520 with pcie 16x3, I’m trying to upgrade my GPU from A2000 to RTX 2000 Ada.
When booting there’s no signal from GPU. Even after boot, the card is not detected on pcie list.
| No display from RTX 6000 Ada | 10 | 1798 | March 10, 2023 | |
| Interesting - Nvidia RTX Ada 4000 RmInitAdapter failed when installed in a pci switch | 2 | 156 | August 26, 2024 | |
| Display Ports Not Detecting Monitors RTX 2000 Ada Generation and Ubuntu 22.04 | 0 | 535 | January 22, 2025 | |
| Interesting - Nvidia RTX Ada 4000 RmInitAdapter failed when installed in a pci switch | 0 | 45 | August 25, 2024 | |
| RTX 3060 not detected, not even by lspci | 5 | 8221 | February 1, 2022 | |
| 79, GPU has fallen off the bus (RTX 2000) | 6 | 276 | August 18, 2025 | |
| RmInitAdapter failed! | 11 | 9982 | November 12, 2021 | |
| RTX 6000 Ada driver not loading after displaymodeselector --gpumode compute | 8 | 1850 | August 12, 2023 | |
| There are two GPU(RTX 6000 ada, GeForce GT 730), Can't log in Ubuntu 20.04 | 2 | 496 | March 1, 2024 | |
| A6000 ADA device not found on kvm guest system | 8 | 1250 | November 9, 2023 |
