RTX 2070 doesn’t report running at max clock rate in the P0 state.
nvidia-smi : Clock graphics 1410 MHz, max clock graphics 2100 MHz.
Is there a way to have the higher clock rate ?
Thanks Patrick
tc@tc-Super-Server083:~/Desktop$ nvidia-smi
Fri Jan 3 13:37:54 2020
| NVIDIA-SMI 430.26 Driver Version: 430.26 CUDA Version: 10.2 |
| 0 GeForce RTX 2070 Off | 00000000:65:00.0 On | N/A |
| 0% 55C P0 39W / 175W | 779MiB / 7979MiB | 29% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2844 G /usr/lib/xorg/Xorg 40MiB |
| 0 3157 G /usr/bin/gnome-shell 115MiB |
| 0 17987 G /usr/lib/xorg/Xorg 304MiB |
| 0 18128 G /usr/bin/gnome-shell 197MiB |
| 0 31232 C+G ./bin/VulkanVideoIO 120MiB |
tc@tc-Super-Server083:~/Desktop$ nvidia-smi -i 0 -q -d CLOCK
==============NVSMI LOG==============
Timestamp : Fri Jan 3 11:51:12 2020
Driver Version : 430.26
CUDA Version : 10.2
Attached GPUs : 1
GPU 00000000:65:00.0
Clocks
Graphics : 1410 MHz
SM : 1410 MHz
Memory : 7000 MHz
Video : 1305 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 2100 MHz
SM : 2100 MHz
Memory : 7001 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
SM Clock Samples
Duration : Not Found
Number of Samples : Not Found
Max : Not Found
Min : Not Found
Avg : Not Found
Memory Clock Samples
Max : Not Found
Min : Not Found
Avg : Not Found
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
