RTX 4060 Laptop GPU freezes on KDE Wayland with driver 570.144
Hi NVIDIA Team,
I’m experiencing a severe issue when using dedicated GPU (dGPU) mode on my laptop with KDE Plasma on Wayland.
Problem description:
When I enable the discrete GPU mode (i.e., forcing the system to use the NVIDIA RTX 4060 for all rendering), my desktop environment completely freezes shortly after logging in. The system becomes unresponsive, I cannot switch to TTY, but background audio keeps playing, indicating the kernel is still running in the background. However, the graphical session is totally locked up. The only workaround is to force shutdown by holding the power button.
This behavior happens randomly but consistently every time I try to use the dGPU mode under Wayland. Unfortunately, logs do not provide any obvious cause, making it hard to trace the root of the issue.
If I switch back to hybrid graphics mode (iGPU + dGPU offloading), the system works perfectly stable, even under high load, for long periods.
That said, I really want to use the dGPU directly for full performance in some workloads and games, and this issue is blocking me from doing that.
System Info:
Laptop model: Lenovo Legion Y9000P 2024 (Model: 82WK, international name: Legion Pro 5i Gen 8)
CPU: Intel Core i9-13900HX
GPU: NVIDIA GeForce RTX 4060 Laptop GPU
OS: Arch Linux x86_64
Kernel: 6.14.4-arch1-2
DE: KDE Plasma 6.3.4 (Wayland)
Driver version: 570.144
Display: 2560x1440@180Hz external + 2560x1600@240Hz internal (both high refresh rate displays)
I’ve attached my nvidia-bug-report.log.gz file as requested. I really hope a future driver update can resolve this, or if there are any workarounds or debug steps I could try in the meantime, I’d really appreciate it.
Thank you in advance.
Best regards,
luke
nvidia-bug-report.log.gz (1.5 MB)
I am experiencing the same issue, NVIDIA RTX 5060 Mobile, driver 590.48.01 KDE Plasma 6.5 wayland.
Hi @luke1997us @papuremo
I have filed a bug 5921281 internally for tracking purpose.
The attached bug report doesn’t seem to have any suspicious logs causing system freeze, the only Xid 31 error reported is associated with Chromium process.
Could you please capture nvidia bug report immediately after the issue and share.
Are you using same Notebook “Lenovo Legion Y9000P 2024“ ?
@vrachatte No, my hardware is different.
Laptop: Game Garaj Slayer R9T (Tongfang/Uniwill X6DR556K Chassis)
CPU: AMD Ryzen 9 8940HX
GPU: NVIDIA RTX 5060 Mobile
@amrits I will attach the file when the crash occurs but this crash happens too random.
Hello @luke1997us @papuremo, Can you please check on latest release driver “595.45.04” and reply back with latest Nvidia-bug-report if this issue still persist. Latest driver has many Wayland related fixes. I will wait for your bug reports.
